Question about Refrigerators
Refrigerator section not cold enough
Freezer section is at -15deg C but the refrigerator section air temp is at +12deg C. I have checked the fan is working (had ice buildup around it) and cleaned condensor behind the panel in the freezer. The thermostat is kicking in and out and the defrost timer is working. The air temp right at the outlet at the control box in the refrigerator section is at 1-2deg C. Have also tried setting the refigerator control to "colder" thus running the compressor longer to no avail. Can someone suggest what is left to check.
Thanks in advance.
Raoul
  • Raz Dec 23, 2008
    tborn6, Thanks for the info, Wont be able to check current draw of the compressor till after Christmas. For the time being had to set the refrigerator control to almost full, the freezer control to almost minimum and blocked off 25% of the freezer outlet grill to force more cold air to the refrigerator. this has resulted in -14deg C in the freezer and +6 to +7deg C in the refrigerator section. Hoping that this will last out till after Christmas when i will have time to check further or buy a new frig..... it's 13 years old so may not be worth throwing a lot of money at it to fix it.
    Can you confirm that the temperatures should be around -15 to -18 deg C in the freezer and +3 to +5 de C in the refrigerator.
    regds and Merry Christmas, Raoul
  • 700 Answers
May have damaged the valves on the unit when it froze up and check the amperaeg of the compressor and so if its running close to the full load amps.
Posted on Dec 21, 2008
Refrigerator
Most refrigerators have only one evaporator that handles both compartments. Only the very expensive ones have two evaporators that cool and independently control the temps separately.
Most simply circulate a small percentage of the cold air with a fan in the freezer section (where the thermostat that controls the compressor is getting its signal from) blowing over to the refrigerator section with the hope that that keeps things cool enough in the refrigerator section. If your LG is one of the common ones, it could be something a simple as a large object blocking the air flow between the two sections or a problem with the circulating fan. Also the dial that supposedly controls the temperature in the refrigerator compartment is sometimes connected to a linkage that determines how far a flapper door is help open or closed. Look for a problem in that linkage or damper door.
Aug 13, 2016 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
When does the thermostat need to be replaced in my refrigerator
Test the fan for continuity. If its OK check the power supply going to the fan if power is there, fan is bad, replace it. Fan blows the cold air to the fresh food section, if its not working very little cold air gets to that side, thats why its so hot in there.
Aug 17, 2014 | Frigidaire Refrigerators
Top freezer works but main frig does not
The way a refrigerator / freezer works is a single cooling coil in the freezer controlled with a thermostat. There is a fan that blows cold air down into the refrigerator section. There is another control that is just a vent control that changes the size of the opening for air flow. if the fan fails you don't get good cooling in the refrigerator section or if the defrost is not working correctly ice will build up and also stop the flow of air to the refrigerator. You should be able to hear the fan working inside the freezer. Replacing a fan motor is much simpler than troubleshooting an icing problem. There are several components that can cause defrost to not work. Bad temp cutoff switch, defrost timer or heater element could be causing that problem. With the unit unplugged and heater element disconnected you can use an ohm meter to measure resistance of the heater, should measure some resistance. Same with cutoff you should measure resistance when cold and none when above cutoff temp. Room temp is well above cutoff and use ice water to see if it closes.
Dec 13, 2013 | Frigidaire FRT21S6A Top Freezer...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Fridge/freezer not working but light is on,located in garage,which iss v cold
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 10, 2010 | Refrigerators
Upper section of refrig. not cooloing. Remainder
check to make sure the freezer fan is turning. This should be inside the freezer unit at the top. It is probably behind an access panel.
If this fan is not turning, not enough cold air will move to the refrigerator side to keep it cold enough. If the fan has died, it will have to be replaced.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is not cold enough.
I had this repaired by replacing the motor-fan in the refrigertor behind the air deflector which sends the air from the freezer to frig. hope this helps. The motor was not working.
Aug 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is cold emnough, it's the refrigerator
Hi..
If your refrigerator is not cold enough you need to check this
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Hope it may helpful for you!!!
Regards
PCmania
Jul 13, 2009 | GE GSH25JFR Side by Side Refrigerator
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Freezer will not stay cold enough
Generally when there is a problem with the freezer section temperature there is also a problem with the refrigerator section temperature.
You can check and make sure the condenser is clean. This is where the heat is moved to the outside air (room air). Look behind the refrigerator for a removable panel. Behind the panel there is the condenser which needs to be cleaned at least twice a year. There is a fan motor which moves the air to remove the heat from the system. This fan must operate at the same time as the compressor.
May 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
