Question about Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive
Can't see Seagate external hard drive on Vista devices with remov
I have a Seagate external hard drive ST3200823ARK USB, wall plug-in powered. I can't see it on the "devices with removable storage" screen on 32-bit Vista notebook. It does show up on the device manager as a USB mass storage device. I tried to install the driver manually but it came back saying the optimum driver was already installed. I switched USB ports with no change.This external hard drive works fine on another computer I have with XP. Any Ideas????? I'm totally stumped.
  • dougv52 Dec 21, 2008
    under my computer device manager it doesn't assign a letter. that's the problem. i'm also running a 4 gb cruser flash drive to take advantage of ready-boost. that works fine device manager assigns it a letter. i've tried switching them from port to port and the device manager sees it fine. even running it without the flash drive doesn't help. how do I get the device manager to assign the external hard drive a letter that's the problem? according to Seagate knowledge base this hard drive is compatable with Vista.
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Is it working? I mean is your computer assigning a drive letter to it? If it's listed in the device manager is it enabled?
  • 1,472 Answers
Dougv52
If the drive is not showing up in My Computer but is showing in Device Manager then you most likely need to assign a drive let you the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 18, 2010
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
How can I power up my seagate 7200.11 500gb external h/drive to my pc
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Oct 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Jan 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Seagate Hard Drive issue
i want drive freeagent pro 500 gb firewere400,usb2.0, eSATA
May 13, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor basics external drive
Hi Nuisance101, I recall your running vista. Vista is a nightmare. If you cound only see the troubles we see on a daily basis here at FixYa you'ed understand. It's a common problem with Vista not seeing USB devices, externial devices. It does & then the next second it doesn't. Same for all external devices. I'm am 100% sure the trouble is not your system or your devices. It's Vista. I have gone over dozens of post from vista users. One would think MS has been on vacation since the release of vista. You can look at vista's web site for help for a possible fix, at this link. (I have no faith). MS blames driver software. Your Maxtor drive is external. Henve no driver software.
So it falls into that vista area of one time vista see's the drive & the next it does not.
Either way I though Maxtor addressed vista issues. I prefer Seagate drives myself. Personally know lots of people who's Maxtor's drives have just gone down for no reason. Seagate bought Maxtor.
http://windowshelp.microsoft.com/Windows/en-US/hardware.mspx
Most of the post from vista users, claim users should check vista's updates often. Since Max Blaster did its job, I'm inclined to blame vista.
I wish I could give you a better fix or suggestion but I'm up against vista. That's why I run WinXP Pro. I do not have these problems.
Best wishes Nuisance101!
Mike
Mar 30, 2008 | Computers & Internet
Seagate (ST3100203U2-RK) (ST3100203U2RK) 100 GB Hard Drive Logo
278 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
