Question about Acer Computers & Internet
Cannot connect to a wirless router - Acer Computers & Internet
  • Aaron Daub May 11, 2010
    You may not have a wireless PCI card installed, try to make a wired connection with an ethernet cable.
  • 679 Answers
Run the setup disk that came with the router or try this, rt clk on my network places and left clk on properties, then it will bring up a ne window where one option will be create a new connection, follow the instructions and you should be ok, with routers, you nees the key the encryption key, make sure you have it before starting or you will mess up your other wireless devices and be in the soup, good luck have patience, and don't give up. Peace,Gym
remember your network will start like theis. 192.168.1 (something from 1-254) try 1-5 first if you can't get in, also in settings it should set them up for you, so click on get settings automatically, call me here if you need more help, many times folks have so many attemts at this that it becomes the problem instead of the solution, I had a friend who had re installed the same router 4 or 5 times, and all I had to do was delete the extra connections, they are only as smart as we make them.
Posted on Dec 21, 2008
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cant connect to linksys
try goin in to the settings for the router it self. ip addres 192.168.0.1 make sure you got the right security key.
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Wanting to connect 2nd computer to internet, have router
If it is by wirless you will need to adjust the wirless adapter setings by going to your network conecsions click on the wirless conecsion and confiqir it to use stronger setings it should have a descripsion for all stings. I hope this will help you. Also do not forget to vote.
Jan 17, 2009 | Gateway Cable/DSL Router - 4Port [ Belkin...
Wirless router
Try This link:
http://www.retrevo.com/support/Netgear-WGT624-Wireless-Routers-manual/id/420dj078/t/2/
Oct 11, 2008 | NetGear WGT624 Wireless Router
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
