My IMEI code is 351851014681440
code 0539687
Thank you
Removing a nokia simlock.. did u simlock it yourself or you forgot the simlock code. any way if you still cant get through with the simlock.. i will sugetst you hard format your nokia through this procedure...have u tried the hard formating.. the hard formating will remove the code and activate the nokia default code for you.. switch off ur fone, then press and hold *+3+(send key) 3-5 mins without removing ur hands,.. then ask someone to help you switch on the fone still dont remove your hands off the key till the fone restats.. this shuld help.. thanks
