Question about GE GSS25SGMBS Side by Side Refrigerator
I have a ge side by side and the water dispencer isn't working but the green light is no water we have ice and the light
  • 700 Answers
What teemperature are you running your refrigerator? the reason is that the water goes into the refrigerator after it goes out of the sollenoid to cool it off. it may have frozen?
Posted on Dec 21, 2008
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
My frige does not dispense water or ice
If when you attempt to dispence ice/water the light dims and the refrigerator seems to shut down unitl you let off the dispenser the main board is bad. http://appliance-repair-it.com/GE-refrigerators.html
Sep 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
The ice dispencer would produce ice
Dear Adriana, I have the exact problem. I have yet to find a clear solution to this problem. The temp in the freeze seems to oscillate too much, and the leaking water led to a damaged light in mine.
Have you discovered a solution? It was recommended by a repairman to replace the controller board for the unit. I have yet to implement this approach. Wondering what others have discovered.
Marco
Dec 06, 2009 | GE PSC25MSS Stainless Steel Side by Side...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
