Question about One For All URC4220 Remote Control
What are the three steps in setting a one for all remote
    Scholar:
  • 73 Answers
Search Remotes http://www.oneforall-na.com/product_support.php
Your Remote http://www.oneforall-na.com/list_codes.php?db_value=access4&remote_choice=URC4220
Manual/Setup instructions http://www.oneforall-na.com/set_up_remote.php
Posted on Jan 10, 2009
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Unable to program new sender to receiver. The receiver should flash three time but the diode lights up a fourth time for a period and the sender is not programmed.
This is the procedure for remote to remote programming, try this!
Step 1. Using a old programmed remote that is already up and running.
Step 2. Press the button for five seconds of the new remote you want to activate and release.
Step 3. Press slowly three times the old remote button.
Step 4. Press the button again slowly and release control.
Step 5. Verify that the new remote works.
Nov 01, 2014 | Building Materials
Dual remote set up
Kenneth,
I would be happy to assist you in setting up multiple remotes to the same TV. To do this is a quick fix. If you want the remote to control the TV1, make sure the remote has a green '1' tab in the bottom. Once that is done, access the system information screen and program the remote to the listed remote address. The steps are the same with the TV2 remote, except make sure there is a blue '2' as the bottom tab. I have provided the steps to program the remote below!
Addressing Remote to Receiver:
1.) Go to System Info screen.
2.) Hold down the SAT button until all mode lights light up.
3.) Enter a number between 1 and 15 using the number pad on the remote.
4.) Press the pound (#) button.
5.) Once the SAT button blinks three times, press record.
6.) Test the remote and see if it works.
Apr 14, 2013 | DISH Network Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
How do I program the oversized brookstone tv remote control to my new Samsung television?
Step 1: Turn on the device you wish to program (TV, VCR, DVD) manually
Step 2: Press and hold the button for the device you wish to program for more than 3 seconds, the red LED will illuminate indicating that the remote is ready to accept a three digit code.
Step 3: Enter the first three digit code listed below within 30 seconds, the red LED will shut off indicating that the remote is programmed.
Step 4: Press the ON/OFF button to verify correct code entry. If the device shuts off then no further programming is required.
Step 6: If the device does not respond, repeat steps 2-5 using a different three digit code.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Jan 13, 2011 | Brookstone 538744 Remote Control
Need a remote for Symphonic tv
should be171,179 or 180 Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your Symphonic from the list which follows:
171, 179, 180
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TV
Why test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Apr 02, 2009 | One For All URC-4021 Remote Control
What are the three steps in setting a one for all remote programing urc-4220
press the device key that you are programming, press and hold the set key until led light blinks twice press code number. if done correctly led light will blink twice
Dec 31, 2008 | One For All URC4220 Remote Control
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Lost code and instruction book?
Orion Codes: 035, 121, 135, 191, 394 Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-New.pdf http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit-Old.pdf Hope this helps, Good Luck :) Please Vote
Jul 10, 2007 | GE RM24911 Remote Control
One For All URC4220 Remote Control Logo
303 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
