Question about Vtech V.Smile Pocket
Short circuit on Vsmile pocket
My Vsmile pocket turns on, however, when my son inserts the game, the device turns off. It seems to be that a short circuit occurs when the game is inserted because if you withdraw the game, the device turns on again. How can I fix this? How can I open the device? Thanks for your support.
  • belmans Jan 07, 2009
    Same problem and there is NO reset button under battery!! (Belgium)
SOURCE: vsmile powers off when game cartridge is inserted
The issue may be the game itself. Check to see if the contacts on the game cartridge are dirty. If all contacts are not clean (all should look the same, clean & shiny), clean with a pencil eraser then wipe with a clean dry cloth to remove eraser bits.
Posted on Oct 07, 2008
  • 87 Answers
SOURCE: Pocket Vsmile
This is a on going issue with these . First of all these take a lots of juice to operate most of the time it is just best to use those store bought batteries . See over time even a small time these rechargeable battery's just don't hold up. Now with this being said make sure you buy the better battery's like lithum ones made for digital cameras and such. If not any thing else this will help you get by tell you get a replacement rechargeable .
SOURCE: Vsmile home unit and 2 Vsmile pockets no longer work! GR!!!
remember the old tv's that used to have black horizontal lines run down them ? Well...... That is what is happenning when I plug in the Vtech smile system. Can someone please help me with this issue
Thank You very much
Single Mom
Posted on Nov 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: vsmile learning shuts off when game inserted
Make sure the system is turned off before inserting the cartridge.
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Posted on Jan 04, 2009
SOURCE: vsmile cyber pocket not working
I had the same problem ..i put new batteries in it and cleaned the contacts of the game with rubbing alcohol..it worked for me..
Posted on Jan 23, 2010
I plug my vtech vsmile in and the game loads but the quality of the picture is blurry i have had people round to check settings etc but it gets no better
My daughter's was doing this too! It turned out there was a short in the wire that hooked to the TV. We bought a replacement and it was fine.
Sep 21, 2011 | Vtech V.Smile TV Learning System
We have a vtech vsmile and it will not work correctly!!! it will turn on with no game in but as soon as you put a game in to play...it goes blank and will not play the game. It won't even let you turn it...
We had the same problem. Put alcohol on a q-tip. Pull back the plastic sleeve on the Smartridge (game) and clean both sides
of the metal contact. Insert the Smartridge into the Smartridge slot and remove quickly. Then insert Smatrige and turn on the power.
I did this to all of the games and now it works like new!
Hope this helps!
Jul 02, 2010 | Vtech V.Smile Pocket
Our Vsmile won't play
Make sure the system is off before inserting any cartrdiges. Things you can try to get the V.Smile TV Learning System to work:
-Tha Mp3 Doctor
Dec 31, 2008 | Vtech V.Smile TV Learning System
Won't work with smartridge
Make sure the V.Smile is turned off before inserting the cartridge. If it is still acting funny:
-Tha Mp3 Doctor
Dec 29, 2008 | Vtech V.Smile TV Learning System
Vsmile cyber pocket not working
Hi I'm ryan, try resetting it. Remove the battery cover, there should be a pin hole with a reset button in it. my daughters did the same thing and i just reset the system and it works fine.
Dec 25, 2008 | Vtech V.Smile Pocket
Turning vsmile pocket on with batteries
All you need are 4 AA battery of anykind. Open the back cover, remove the Vtech rechargable battery pack and insert 4 AA batteries in its place. Now your child will enjoy there Vsmile again.
Dec 14, 2008 | Vtech V.Smile Pocket
Power won't come on
This is a problem with the cartridge not the console. The cartridges get dirty and then the console acts as if its broken because it can't read the cartridge. Pull the purple flap up so that you can see the inside of the cartridge and clean it with an alcohol based cleaning solution. Dry the cartridge fully before inserting it back into the console. I have done this for serveral games and they have worked again. A couple of games have just broken and refused to clean up. Hope this helps, let me know.
Dec 03, 2008 | V.Smile V Smile Console
Vsmile powers off when game cartridge is inserted
you are suppose to put the cartridge in first and then turn on the game.
Sep 01, 2008 | Vtech V.Smile Pocket
You should definately call customer service! I had to do this with our vsmile and they were very helpful with tech issues immediately. You can call them at 1.800.521.2010. One thing to try, they had me do this on the home unit. Unplug everything, then hold down both buttons on the front for one full timed minute. This resets the unit. See if this works for you. They will ask you to do it on the phone first anyway. If not, I hope they are able to suggest other helpful solutions for you! If not, you can find a good deal on a new one on ebay. Good luck! I know how much the kids enjoy this unit!! :)
Aug 13, 2008 | Vtech V.Smile TV Learning System
Vtech V.Smile Pocket Logo
56 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Keith Koene
donny ardalando
donny ardalando
Are you a Vtech Toy Expert? Answer questions, earn points and help others
