Question about Smith and Wesson Security Products Smith & Wesson Tactical Tritium Dive Watch SWW-450
Hi folks i have 2stanles steel 4"357 and they both miss i of the
6 shots and if i pull the triger 6more times it some times fires it is amod 66-2 above it is AAT 8785 can you please help solve this problem thank you in advance my email isjproccojp67@gmail.com
  • 2,338 Answers
You submitted your questin into the wron topic (watches).
Resubmit into the appropriate one.
Posted on Dec 21, 2008
Adjusting a steel band to fit my wrist.
Hi , Steel Bands are made of pieces which connects with pins.
just pull out the pins of the exact piece that you want to remove and then join them by inserting the pin.
Also for small adjustments it can fix by repositioning of end to lock attachment.
Apr 17, 2017 | Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
I want to know how to change the clock. Tag Heuer 2000 Classic Silver Dial Steel WK1312-0
Hi! your watch probably has a screw down crown which is a feature found in well made watches. Turn the setting mechanism on the watch until it unscrews then pops out a little , pull it out two clicks to set your time, and one click to set your date. The one click setting can tricky it is what we call a halfway setting but you will feel it pulling the stem in and out. Then make sure to screw the crown back in this is a water resistant feature. Thank you! hope this helps:)
Sep 06, 2011 | Tag Heuer Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
Setting a cartier chronograph watch
  1. click the top button to stop the second hand
  2. click the bottom button to reset the timer
  3. pull the crown out all the way
  4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
  5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
Sep 15, 2009 | Cartier Tank Francaise Chronograph White...
Can't pull out knob on side of watch to change time
You may have screwdown crown. Try to unscrew it first and then pull out. If the crown is turning but you can not pull it out, there is a rust in the watch and you will have to find your nearest watchmaker to sort that.
Rate, please.
Mar 28, 2009 | Invicta 2636 Ocean Ghost Chronograph Watch
Versace flc99d001s099
good after noon,to set the time and is depend on the model of your watch,if your watch is analog use the crown to set the time and date just pull the crown slowly and wind it,but if your watch is digital use the button to set the time,thank you !....
Aug 29, 2008 | Versace Gianni Atelier Chronograph
I bought a kenneth cole reaction watch kc1292 A126-06 Solid Stainless Steel, (Digital Watch)(with a fat watch black leather bracelet) from Las Vegas JUly 26, 2008 and said carries a lifetime warranty. My...
Hi Junell ,you can't pulled out the crown,because it is threaded.First unthreaded it before you pull,first pull is for DAY/DATE adjustment.Second or full pull is for Hour / Minute setting,that's all.Feel free to ask and post a message,so i can assist..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Jul 30, 2008 | Watches
Smith and Wesson Security Products Smith & Wesson Tactical Tritium Dive Watch SWW-450 Logo
199 people viewed this question
Top Smith and Wesson Security Products Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Smith and Wesson Security Products Watch Expert? Answer questions, earn points and help others
