Thanks a million! I finally don't have to manually tune the silly thing every time! :-)Thanks a million! I finally don't have to manually tune the silly thing every time! :-)
You can't post conmments that contain an email address.
start the car turn the radio on scroll to the station you want then push and hold the preset button 1 thru 9 untill it beeps then go to the next station you want to set and do the same.
Finally sussed out how to (re)set presets, overall you need a little patience: Probably best to press Autotune before we set off and let it do its thing. Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play. Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again) Use dial to find station you want AND LEAVE to tune in. Press AND hold presets down until number flashes. Press jog/select once briefly (normally). Press presets once briefly...it should now say "Saved" Leave to save for a few seconds. Voila! You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
hi, there is no auto presettingavailable. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER". 2. Press the FM/AM button to select a band. 3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it, 4 .Press the MEMORY button.( on remote) 5. Within 5 seconds, select a preset channel to store the station using the PRESET buttons of the remote control unit. 6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listeningpreset ed station ,Press the PRESET button repeatedly until the desired preset station is found. ok
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Holding the button is supposed to work. This from owner's manual:
PRESETTING A STATION:
Tune in the desired station.
Push one of the station selector buttons (1-6) and hold it until a beep is heard. This sets the station to the button and the button number (1-6) appears on the display.
Each button can store one AM station and two FM stations. To change the preset station to a different one, follow the same procedure.
The preset station memory is cancelled when the power source is interrupted by battery disconnection or a blown fuse.
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
I was looking for a solution of my problem but found your problem. I have a manual but it is not aesy to find a way to erase all presets. Read this selection till the end and you know a way!
It is possible to change the MW tuning interval. You can do this by pressing the POWER button while pressing the BAND button during power is on. To reset the interval, repeat this procedure.
NOTE
- When the MW tuning interval is changed, all preset stations are cleared. The preset stations have to be set.
If you have the owner manual check for reset and reset the unit. If you don?t have the manual unplug the power cable for a wile and then try again.
Good Luck
Toufic Malek
