Question about Sony KP-53XBR200 53" Rear Projection Television
Ghosting images sony 57 inch projection KP-57WS500 has ghost images looks almost like a shadow of the original image behind the image. I think this a convergence issue but I would like to know how to fix it any help you can give me on this would be greatly appreciated
  • ss58918 Dec 26, 2008
    53in. sony double image nothing happens when i hit the flash foucas botton. how do you fix the problem, and aprox.how much are parts
    Sergeant:
  • 233 Answers
The color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-040, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
The image has a shadow in the screen and little distorsion by the corners
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV and check if it helps.
Jul 27, 2010 | Sony KP-57WS500 57" Rear Projection...
The colors are not coming together. I can see red
You have bad convergence amplifier ICs. May also have associated low value resistors and or pico fuses open.
Oct 16, 2009 | Sony KP-57WS500 57" Rear Projection...
My sony projection xbr 57 in hd is ghosting
if it's red, blue, or green ghosts, then you need new convergence chips, stk 392-570, have to be soldered in.
Sep 19, 2009 | Sony KP-57WS500 57" Rear Projection...
The red and green do not line up properly has ghosting images
go into the convergence mode in the customer menu---if either red or blue do not adjust in any direction---bad convergence Ic's, The Ic's are located on a rather large heat sink with fins and should be stk-392-560's(there are 2)
Aug 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv turns on but has a shadow around evrything
Do you have any speakers or magnets next to the tv? If so, that is not good.
It may be a convergance issue. Check to see if you have any adjustments on the back of your tv to adjust picture. If not, if may be a faulty capacitor that needs to be replaced
Jul 02, 2009 | Sony KP-57WS500 57" Rear Projection...
My Sony KP-57WS500 57 inch TV is showing a double image. The pictures have a shadow.
If the colors are separated, this is a convergence problem that can be as simple as poor connections on the convergence ICs or defective ICs. Please provide a more detailed description if you can. If you can solder, you may be able to fix this yourself. Let me know if you wish to attempt the repair.
Thanks,
Dan
May 05, 2009 | Televison & Video
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500
did you replace or check the 4.7 ohm 1/2 watt resistors or the 6 pico fuses when you changed ICs? If not thats most likely your problem.
Jun 21, 2008 | Sony KP-57WS500 57" Rear Projection...
GHOST IMAGE ON KP-43T90
this problem is caused by the pal 50 - 60 meg problem, the sony runs at 50 megs, if you have a 60 input from an hdmi lead you will get ghosting
Mar 05, 2008 | Sony KP-43T90 43" Rear Projection...
Double image
have you done convergence? and is there a auto focus?
Jan 07, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KP-53XBR200 53" Rear Projection Television Logo
181 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
