Question about E-Machines eMachines Desktop PC
I have a E machine when I turn it on the fans start up but all I get is a beep,beep beep ect. can any body help?
  • 24 Answers
If it has 3 beeps it has something to do with the Ram so check that and check everything to see if plugged in
Posted on Dec 21, 2008
Fisher and paykel Smart Drive 9 excellence 7.5 washing machine wont fill at the start it just makes sounds like its trying then starts beeping?
the water soleniod has went bad pull out washer look to where water lines hook up to it turn of water to them then remove hoses unplug machine remove the soleniod valves make sure you write down the wiring order and hose placement on something get new valves replace rehook water line turn on water ect.
Aug 20, 2014 | Washing Machines
2003 Chevy Impala, running hot. Changed fan shroud because cooling fan wouldn't turn on, switched out fan relays, no check engine light. Cooling fan still will not turn on.
Would turn the key on no need to start it and unplug the ect engine coolant temp sensor. If fans come on then suspect a faulty etc which may not turn on the engine light. Which engine is in the vehicle so I can help locate the ect which is usually by the thermostat housing.
Jun 12, 2011 | 2003 Chevrolet Impala
My washer did not drain and start to beep every second
Hi just read your posting.If your machine is beeping then a series of lights will be lit and these lights will be in a row of 8 lights.Starting from the left to right on the row which lights are lit when the machine is beeping,Is it the 2nd and 4th or the 1st and 7th ---etc---?Try this also if your machine is not draining.Bail some water out by hand from the machine ,enough to lean the machine back so you can look under the machine.Now when you can see under the machine ,look to the front right and you will see a black fan.This is your pump.Now turn the fan a few times to loosen the pump.The fan should turn freely.Now put the machine back on its feet and select a spin cycle and push start.The machine should start to drain.Please reply on how you got on and with the information on the lights that are lit.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
When i turn the computer on it starts then
SOS beeps are post codes the computer sends to alert you of problems detected during start up.
The beeps can mean anything from over heating to bad memory detected. Find out what your Motherboard bio is and check Here. This has a handy beep code listing for many of the common mother boards.
Hope this helps!
Nov 17, 2009 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
My Fujitsu Siemens Scaleo P
Hi wicklow123,
Sorry I haven't gotton back to you sooner. Its summmer here & I ride cross country.
I'm betting its the fan.
The fan that is running very slow. If that fan is for the CPU than replace it as soon as possible. A CPU fan should be running no less than 2000 rpm. Average speed is between 2000-3200 rpm.
Please define the beeps you are hearing. (Ex. 3 short & 1long, six short & repeating ect.) You'll need to know the name of you're bios. (Ex; Award, AMI, ect.) Go to this link & find you're bios. You should be able to find what the beeps are telling you is wrong & what to check. (There is a list of Bios on the left of the site.)
http://www.bioscentral.com/beepcodes/awardbeep.htm
The video card. If its all copper fins I wouldn't worry. Be more concerned about the bios beeps & fan. It wouldn't hurt to add a side case fan which will aid in bringing in fresh air to both the video card & CPU.
(Link for case fans & more). http://www.xoxide.com/80mmfans.html
Good Luck!
Mike
Jul 24, 2008 | Computers & Internet
Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
May 17, 2008 | E-Machines eMachines Desktop PC
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Black screen and beeping.
try to use pci card to getto screen agp ect ok maby bios thinks its that output reset it pull out battery then back in
Feb 03, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
E-Machines eMachines Desktop PC Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
