Question about Music
Guitar amp channel switch repair
The channel select switch doesnt work. theres no distortion when switched on. it doesnt light up either. clean works fine
  • Anonymous Jan 06, 2009
    yea man my fender hot rod deluxe is having the same exact problem. you ever find a way to fix it?
I just bought one used...same problem with the channel select switch on the amp...but, like Solution #1 says, the foot switch works fine so...no worries:)
Posted on Aug 09, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Posted on May 29, 2009
How do you use a four way footswitch
Need more info. What kind of foot switch and what are you hooking it up to. For guitar they are used for switching distortion to clean on 1 switch, one for reverb, one for chorus, and possibly 1 for bypass. All depending on the amp you use, and what effect the amp has built in it. Some amps only have clean and destortion which make the other channels on the footswitch useless. Hope this helps.
Dec 31, 2014 | Music
My hot rod deluxe switch channel from clean to distorted for him self without me touching anything?
I have worked on a number of these amps and found the most common cause of intermittent channel switching is dry joints on the foot switch jack or the contacts becoming contaminated. In either case you will require a tech to look at your problem as the main board will require being lifted out of the metal chassis for inspection. Because of the ribbon type cables between main board and the board that supports all the valves I recommend professional help . Not a DIY job
Apr 24, 2014 | Fender Hot Rod Deluxe Guitar Combo...
I have a Guitar Research Amplifier Integrated Solo Tube Series T64RS: Channel 1 (which I assume is the clean channel) will cut in and out and the light will dimmer with it and it makes a fuzzy poof sound...
As far as I can tell from this; you could have either one of two problems.
1. Your guitars output or amps input could be loose. This happened to me with my bass. All you have to do to fix that is get into the electronics (usually accesed behind plates with screws), find where the cord goes and pinch the two clips together to make the fit tighter
2. There could be a problem with your power; which could possibly originate from the socket itself, a loose attachement of the power cable to the amp, or a loose cable inside the amp. Id reccomend plugging some other electronics into the wall and seeing if their power dims, if they dont then plug in and unplug the part of the cord that attaches to your amp and if that doesnt work you'll need to take i in to an expert to look at the internals of it.
Jul 28, 2013 | Music
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
Hey, the clean channel on my Marshall 250dfx Combo amp isnt working the distortion and everything is working as normal, but the clean channel makes no sound at all, i was wondering if you can help?
The switching is done electronically by an analog gate chip. On IC9, check if the signal on pin 8 changes with switching between clean and OD... This is the actual signal that changes the gate. If you don't see a change there of say 5 volts, then the problem is in the circuits that drive this gate. If the signal is there, then the problem is in the clean channel audio op amps or the components around them. Let me know the results of the test.
Oct 18, 2010 | Marshall Amplification Marshall MG250DFX...
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
746 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
