Question about Philips FWC577 CD Shelf System
Wont work when i turn volume up?
It works fine up to about 7 or 8 but if i turn the volume past that it just goes silent. it just started doing this for no reason? i took it apart to the point where i was literrally holding a pile of pc boards in my hand but couldnt find anything worng with it? so i put it back together and it still wont work right?
  • Layton Zeiner Apr 04, 2007
    Its not the control, its definitely a power/amplification/drive/amp issue. im familiar with pots, it wouldnt be acting the way it is popping out and in if it was the pot. It sounds like a compression pop when it goes out then lightly compression pops as it comes back in. basically, a better way to describe this would be that when i turn the input level of music on the computer down to 25% i can turn the stereo to max and it still works perfectly, but if i turn the computer volume up, it cuts out and goes silent like it dont have the juice to go that high anymore.
    Genius:
  • 1,074 Answers
Clean the volume control it could be dirty
Posted on Apr 04, 2007
I have an RCA Tablet RCT6773W22 Android Version 4.4.2 The tablet is in Silent Mode.
I'm betting the volume switch is actually stuck and that the sound is just going down to "silent" the moment you release the "up" button. Does the sound get loud and just fade away? If so then that's probably it.
Feb 20, 2017 | RCA CA 7" Tablet with 4GB eory 28458515
My tablet was working fine the next day I went to use it I turned on it wont go past trio@9dualcore
if other solution fails, you can do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
try it, it works and start thngz afresh
Apr 04, 2015 | Mach Speed Trio Stealth G2 Tablet -...
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Everything was working fine, then the sound quit working when we play the DVD player. Switch back to TV-DVR mode and sound is fine. Change o DVD and it goes silent. We have to turn up the volume on the...
please try to find new firmware for this model, I guess it is HDMI version compilable problem. maybe after update firmware could fix your problem
Mar 17, 2011 | Yamaha HTR-5560 Receiver
Switch off speaker phone on dash htc
When you are calling somebody, click menu, then click Turn Off Speakerphone. If you want to disable the system volume, go to the volume control settings (Start, settings, click more, click more again, then click Volume Touch Strip.) Once there, you can set the touch strip to work when in a call, or for calling and when your on the home screen. If you don't want any volume on your HTC Dash, you can set the volume strip to work with the system and in call volume, and then turn the volume all the way down, and then change the setting to just work with in call volume. You can also go to profiles, and select the silent mode, but make sure you change all the sounds to the quietest as possible (ie for call, select silent, and for reminders, select vibrate.) Hope this helps.
Jan 15, 2011 | T-Mobile Dash Smartphone
I cant hear in comming calls, it flashs and goes to recording but no sound. Anyone know why ?
Phone is in silent mode. Check your owners manual or user guide for how to change out of silent mode. Try turning up the volume at the main screen, this works for Samsung phones :)
Dec 16, 2009 | Sanyo MM-8300
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
Humming Noise
There might be something wrong on the volume dial, or the speaker connection.
SOLUTION: Check the speaker cables on the back.
Mar 28, 2008 | Philips FWC577 CD Shelf System
Earpiece sound silent volume 7 sounds like a volume 2 or 1
Hi, just remove the cover and check the speaker volume.. may be some new plastic coating an the new cover will be blocking the sound from coming outside properly. If it is not the case then please do come back all the best sreejith
Jul 16, 2007 | Motorola Mobility RAZR V3
Philips FWC577 CD Shelf System Logo
107 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
