Question about Clarion VRX935VD Car DVD Player
Wiring diagram my cousin gave me the radio he dosen't have the wiring diagram. vrx935vd clarion
  • 15,935 Answers
Clarion vrx935vd how to hook it up. i have a black cord and i think its a adapter and i dont no where to find it or whats it called but i dont no how to find it or hook it up.
the adapter would be for a sirius satellite radio
here is the wiring diagram
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Sep 20, 2009 | Clarion VRX935VD Car DVD Player
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
My clarion vrx935vD doesn't come out.
simple thats because you must have forgot to plug the small adapter in the back of the deck that has a yellow and black wire coming from it. if you have then one of those two wires are not hooked up to the right place. and if that fails then either u have a bad connection somewhere in ur car wire or in the inside of ur deck. i had the same problem when i hooked up mine i just forgot to hook up that adapter because its really small
Oct 06, 2008 | Clarion VRX935VD Car DVD Player
Wiering
For a Clarion VRX935VD, installation and wiring information may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 12, 2008 | Clarion VRX935VD Car DVD Player
Help with install on clarion vrx935vd
The green would have to be connected to the handbrake indicator switch. Additionally, Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Jun 13, 2008 | Clarion VRX935VD Car DVD Player
Robert
The best solution is to google Clarion and serial # to deck, also include manual. EXAMPLE: Clarion VRX935VD Manual....And in that manual there will be a wire connection page. It will show you the best possible way to install the deck into your car.
Jun 12, 2008 | Clarion VRX935VD Car DVD Player
Depends on the type of car you have and everything, I think you should take it to a professional.
Apr 15, 2008 | Clarion VRX935VD Car DVD Player
I love Clarion
1st RED is + direct to battery
Yellow is + pwr to ignition so when you turn the car off the radio can still say on if you choose
black is - and ground
these are importantant first. once you have pwr you can easily work out which of the 8 other wires are pairs 2 frnt spkrs and 2 back speakers if theres 2 extra plugs for the amp or woofer(if screws run a nice thick speaker wire. But with Clarion I dont beleive you need an amp or woofer thats how good they are just have kickass speakers frnt an back
you should be able 2 find the pwr cables from the existin radio if not the yellow wire leads to the igniton and you can run a red wire staight to the battery and screw the black wire to the metal chasis(oh the blue wire is for a pwr antenna or aux and is not needed unless youve got a pwr antenna.
your speaker color code will be like eg.grey and grey with white stripe,will be one pair green another pair ,but the 4 spker pairs are skinner than th pwr cables
Spkrs have a + and - too the difference is you cant blow the spkr by trial and error its just if its wrong it will sound muffled so try both ways then youll know whats best. pwr must be correct make sure red on red and blacks on black then press on then play with your speakers then find the yellow cable that runs to the ignition then to the radio so when you turn the ign the radio comes on and when you turn the motor off you can turn the radio on cos youve also got a direct to battery connection.
Man you are gonna love your sound system
Im happy for you
Clapster
Feb 24, 2008 | Clarion VRX935VD Car DVD Player
Clarion vrx935vd
Do you have an external amplifier for all your speakers?
If you answer is yes, you need to check the remote wires,they may be connected in the wrong place.
the wire for the amp's remote is the BLUE/WHITE STRIPE.The BLUE (only) wire is for the pwr antenna,in other worlds if you connected the pwr antenna wire to the the remote in to the amplifiers,every time you insert a cd,your unit will swtich to cd mode and will turn the pwr antenna voltage off.
Just switch the wires.
Dec 02, 2007 | Clarion VRX935VD Car DVD Player
Clarion VRX935VD Car DVD Player Logo
592 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
