posted by go tribe on Apr 03, 2007
after i bring up my menu and then hit exit the tv button blinks and then brings up the menu again..the only way i can keep the menu from popping back up is if i cover the infrared signal to the tv on the remote otherwise the menu comes back on..my tv is a panasonic if that helps..this is an annoying problem..like some help if anyone knows how to stop it..thanks
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 13, 2008
we have the codes, but lost the directions on how to code in the numbers
Best Solution
posted on Apr 04, 2007
your remote has an defect to verify it take out the batrries from out teh remote and see what the tv do.if you still have the problem replace the eeprom it could be defected.good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA RCU300WBL Remote Control
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
Programming Magnavox codes into...
How do I program the Magnavox... Answer This...
systemlink 3, code number for...
I need to know how to program... Answer This...
cant program my remote
I think I have tried everything... Answer This...
remote not changing channels
I did a auto setup for my tv... Answer This...
Repair Service
Find Remote Control Repairman Near You:
Find Parts
