Question about Timex Expedition 84601 Wristwatch
Timex Expedition speed
Any way to adjust the speed of the watch? Watch runs slow. Loses about 5 seconds per day or is this within normal specs?
  • 2,334 Answers
It's not ok. Usual specs are +/- 1-2 secs a month, no more.
Try battery change first and if it doesn't help, go and see your nearest watcmaker to solve the problem.
Posted on Dec 21, 2008
Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
My watch loses time.
mcdevito75 here, Your Timex may need serviceing or a new Battery. Look for a small watch repair shop in your area.
Sep 21, 2010 | Timex Expedition Camper Watch T40791
Dear Sirs! My new (1month) Longines automatic watch hastens each day (and night) four seconds.Model L4.721.2 Is it normal or I have to turn to the laboratoty to fix the problem?! Thanks a lot Iosif
An automatic watch that gains 4 seconds in a day is good.A new Rolex is rated at 5 seconds per day so 4 seconds is well within what you can expect for your watch.As a tip when the watch is off the wrist place on its side,gravity slows the operation of the watch just a fraction.This is called positional error and may help.
Regards
Aug 19, 2010 | Longines New La Grande Classique Presence...
How do I adjust the time and date on my Timex Expedition watch
Hi, the upper of the two watch stems is turned counter clockwise (looking at the stem) until the desired function (i.e., format, date, time, chrono, timer) appears. To set that function, pull the upper stem out and turn CW to advance & CCW to go back. Once hours & minutes are set, the stem can be pushed in upon a mark to start at zero seconds. For the day of the week, turn the upper stem CCW until date appears. Pull out the stem, to detents or positions, and this will allow the day to be adjusted.
Take care
Mar 25, 2010 | Timex Expedition47761 Wristwatch
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    My watch needs battery evry 15days
    Your problem may be that the back MUST be replaced in exactly the same orientation as it was removed. On mine the lettering on the back must oriented so as to read with the top at 12 O'clock. In other words, if you look at the watch face with 12 at the top (normal) then rotate to the back and place the back on so the words can be read. I hope this makes sense. Top of the words on the back must be exactly at 12 O'clock
    Apr 17, 2009 | Timex Expedition 84601 Wristwatch
    Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
    There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
    Use your users manual to set the watch.
    By the way: Timex is one of the worst watch producers.
    Jan 07, 2009 | Watches
    Outdoor Timex Expedition watch
    Dear sir,
    i bougt a watch timex expedition indiglo wr 50m from ansal plaza in shopper stop in this watch i find some nylon type of thred in this watch when i gone on there he is saying that leave it for 7 days i bougt from there on aprox 20 days before plz suggest me waht have to do
    my contect no 9818190399
    my mail id is delhi@inspaninfotech.com
    and ashish_kumar904@yahoo.com
    Nov 07, 2007 | Timex Outdoor Camouflage Expedition®...
    Timex Expedition 84601 Wristwatch Logo
    541 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
