Question about Whirlpool Duet GHW9150P Front Load Washer
Clean pump filter
How would I locate the filter?
  • 85 Answers
Remove bottom panel on front of washer should be 3 torx #20 screws pump is located right in front center (i will pich the hose to the pump from the tub to keep from losing water) unscrew cap on front of pump and clear out basket beware there will still be some water so have some towells ready hope this helps you out if there is anything eles you need please let us know
Posted on Dec 21, 2008
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Location of fuel filter Holden barina tk 2006
Under the rear passenger seat, you will find a plastic hatch, it is in the fuel pump.
Not serviceable item. I did take my pump apart and clean the fine filter. The only way to change the filter is to get a new fuel pump.
Aug 11, 2011 | 2002 Daewoo Lanos
Were is the drain system manualy
To access thr pump and filter, remove lower rear cover of washer.
The pump and filter are located at the bottom rear right of washer.
To clean filter, remove large black hose onto drum, and clean filter inside hose.
Hope this helps.
Jan 15, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
Dec 12, 2009 | Hotpoint WMA54 Front Load Washer
I need to clean the filter.
Hi.
To clean filter, follow details as listed.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove the hose onto the pump, and check for obstruction here and in the pump.
This should solve your problem.
Dec 05, 2009 | Hotpoint WMA50 Front Load Washer
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Water wont drain
OE-pump blocked. Disconnect the power before attempting any work. Use of an RCD (plug in power breaker) is recommended.
Disconnect pump from sump hose and check for obstruction in either item. Pump removal: power off, remove cover, locate pump, (attached to other end of drain pipe).undo 2 wiring connections, 2 hose connections, and pump mounting screws. Remove pump chamber - some are held in with screws, others clip into place. Check for foreign objects round the impeller. If pump chamber is clear, may be a fault with the pump motor - in which case, replace.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Good Luck!!
Mar 26, 2009 | LG WM-2277HW Front Load Washer
Cant locate ''pump'' on whirlpool awo/d 5556
Hi, Whirlpool manuals do say that but they only mean the filter not the pump as this is self cleaning!
Hope this helps.....
Feb 27, 2009 | Whirlpool Washing Machines
How do i clean the pump on my whirlpoll awo 3551
Jan 25, 2018 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
