Question about ASUS A7N8X-X Motherboard
Hello m8 my problem is the power switch connector won't work proberly, i have to pull it out of the motherboard and put it in again, and then the computer starts on it own??
  • 45 Answers
Look up the manual for your case and motherboard and make sure you are connecting it to the right pin, some pins recieve constant power.
Posted on Dec 21, 2008
Msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Dec 05, 2012 | Computers & Internet
Wont start up msi vr603
Hello, just power off your PC and try to reset the motherboard configuration. Follow this steps:
1. Pull out the memory card, bios battery and the connector that connect your hard drive its either IDE or SATA connector. Then pull up the jumper of the bios then put it to the reset jumper settings.
2. Turn on your motherboard then let it for about 5 minutes.
3. After 5 minutes, turn off and put back all the devices you just pull outed and try to put the jumper settings to normal.
4. Then Turn on again and see if the motherboard will turn on.
5. Do not forget to clean the memory card with an eraser.
Jul 19, 2012 | MSI K8MM-V Motherboard
How to put the on/off wiring to the asus p4s800 motherboard
Hello
In your lower right side of your CPU there are connectors which is intended for power switch and reset switch which is used turn your power on and off in your CPU. That connectors are connected to a normally open switch. Or you can even short it with a small wire to turn on you PC. If you want to automatically power on download on this software on this site http://www.lifsoft.com/
Hope this can help you..
Jul 19, 2011 | ASUS P4S800-MX Motherboard
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I HAVE AN OLD AMD DURON WITH A MOBO ATTACHED OF COURSE BUT THE PROBLEM BEING IS IT POSTED WHEN I FIRST SET IT UP NOW I WENT TO TURN IT BACK ON AND IT WONT EVEN POST AT ALL ITS ALL POWERING UP BUT NOTHING...
hello sir, try the following.
  1. turn off the pc and remove the side cover, locate the memory module, and reseat it (remove and put it back). power on the pc. Still not working?
  2. off again, remove the memory modules again and clean its gold plated contacts by using an eraser (the pencil eraser) then put it back again. power on. still not working? do 1 and 2 several times. (make sure that the memory modules are good)
  3. If several times has not worked, try to isolate the problem by removing all the connectors except. 20/24 pin power connector, the vga cable, front panel leds and switch. do 1 and 2 again.
  4. still not working? check your motherboard connections and review your work?
  5. is you pc 220 v plugged on 110v?
  6. Reassemble the board again.
Sep 14, 2009 | AMD64 mobo1 Motherboard
Video Not showing up , no Beap on Pwr Up, just running, Whao I Do?>
hello sir, try the following make, sure that your power supply is working fine:
  1. turn off the pc and remove the side cover, locate the memory module, and reseat it (remove and put it back). power on the pc. Still not working? (make sure that the 12 volt 4pin molex power connector is pluged on the motherboard)
  3. If several times has not worked, try to isolate the problem by removing all the connectors except. 20/24 pin power connector, the 4 pin 12volt power connector, the vga cable, front panel leds and switch. do 1 and 2 again.
  6. Check *********** board.
let me know your progress.
Sep 13, 2009 | Computers & Internet
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
2 problems
Sounds like a short in one of the wires. Try testing the power supply with another system, if all works properly then it is a short in the motherboard. Hope this helps.
Dec 21, 2008 | ASUS A7N8X-X Motherboard
Programme dial
that is your only solution but u might find u can buy a second hand machine that works for u to get parts off this will proberly be cheaper than buying a timer thats what id do u get more for your money m8
Aug 14, 2007 | Candy AQ130 Front Load Washer
ASUS A7N8X-X Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
