Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-zero 511 Refrigerator again!
The fan is working but not enough cold is blowing into the refrigerator. Now what should I try??
    Problem Solver:
  • 8 Answers
The problem could be one of many. Make sure the condencer is clean and that the condencer fan is working. Make sure the light is going off when the door is closed by pushting the door light switch in. Next the compressor would need checking and then the most likely is that your low on freon which most likely means a new refrig evaporater .
Posted on Jan 23, 2009
Sub zero refrigerator part is not cooling enough
First clean your condenser. If that doesn't do it there are many things that could be going on depending on your model. You should probably call an authorized servicer.
Jul 22, 2014 | Sub-Zero Refrigerators
The Sub Zero bottom dram freezer has stopped working
HI,
What does you freezer do? Does the lights work and fan work? The fan works with the cold control, if the light switch fails the unit will defrost in about 3 - 4 hours, will remain cold though, just not frozen. I need more information to direct you correctly.
I am here to help
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
I have a sub zero 561. The freezer works properly but the refrigerator is not cold enough. I turned temperature from 5 to 7 but no change
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Sub-Zero 561 / F
Sub zero 611 refrigerator error code 40, freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 11, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 611 refrigerator error code 40, freezer will not get cold enough but refrigerator compartment working
code 40 compressor for the freezer side over runing. check the coils upper part of the unit. or condenser fan motor. easy things to check.
Mar 18, 2010 | Sub-Zero Bottom Freezer Refrigerator
Refrigerator is not cold enough
Have you checked to see that the inside fan is blowing. It may not blow with the door open so manually operate the door switch.
Jul 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
266 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
