Question about Oster 76076-010 Hair Trimmer
Have pro clippers do not have instructions for changing blades
Oster Power Pro cordless clippers model#78400-01A
Can you send me instructions for how to change the blades. I took one blade off and I can't figure out how to get it back together again.
Thank you. Barb
  • Anonymous Dec 31, 2008
    no oster blade changing instructions
  • 22 Answers
Schematics are located at this link. Hope this helps.
http://www.clipperrepair.com/parts.htm?brand=8
Posted on Feb 02, 2009
I just got a Oster Golden A5 and it came with it 2 tubes of lubricating oil and I don't know where or how to use it? Please help
For lubricating the between the blades and also the drive spindle.
Instruction Manuals - Oster
www.osterpro.com/service-and-support/product...manuals/instruction-manuals.html
Shop Oster Pro. Products · Specialty · Videos. Service & Support. Product Registration · Product Support · Service Center Locator · Sharpener & Repair Locator · Distributor Locator · CA Transparency Act · Return Policy. My Account. Create An Account · Update Profile · View Order History · My Wish List. About Oster Pro.
Oster Golden A5 clipper. Basic Service - YouTube
? 11:59
https://www.youtube.com/watch?v=whvY2VPRWTM Oct 27, 2015 - Uploaded by Cloud's Diamond Sharpening
Basic service. Parts needed, Link, Lever, Hinge, Latch and 2 screws. Enjoy! Lightless Dawn by Kevin MacLeod is ...
Oster Golden A5 Clippers Manual - YouTube
? 0:33
https://www.youtube.com/watch?v=SUY745pglq4
Feb 20, 2017 - Uploaded by Nada Lina
Oster Golden A5 2 Speed Clipper - Duration: 1:15. MrTryan88 8,704 views · 1:15 · NOT CUTTING? Taking ...
[PDF]Service Manual- Clippers - Northern Tails Sharpening
www.northerntails.com/images/Oster_Clippers.pdf 73863. LABEL. 1. PARTS LIST. GROUP II CLIPPERS. USE ONLY GENUINE OSTER PARTS -. USE OF WRONG PARTS MAY BE HAZARDOUS. 120 VOLTS, 35 WATTS, AC OR DC. X. X. GOLDEN A5. X. X. X. DETACHABLE BLADES. X. X. X. 115 VOLTS, 35 WATTS, AC OR DC. X. MODEL OR SERVICE NO. COLUMN. 1. 2.
Jan 13, 2018 | Oster Health & Beauty
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I have an Oster Golden A5 2 Speed animal clipper and don't know how to change the blades. I live in Australia so can't go to Oster. How do I do it please and is there a comprehensive Oster Manual? Thanks,...
hi, if you look at the blade while its attatched to your clipper, at the back edge of the blade there is a black metal peice called a Latch push this towards the blade and pull the front edge away from the clipper it will hinge away then you can pull it straight off.
As for an instruction manual if you have no luck contact us and we can send one to you.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster dog clipper Model 103582-010-000 and would like to know what blades I can use, also where I can get an owners manual. Thanks, Dan
Blades are available online at
Oster
800-887-6682
OR
CacheBeauty.com
But once the plastic clip that mounts the blade to the unit brakes you are screwed. Oster can't supply that anymore. You can always sharpen the blades and make sure you keep them lubricated going forward. Google sharpening clipper blades to find instructions.
Steve O. Minneapolis, MN
May 19, 2010 | Oster 76076-010 Hair Trimmer
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Power Pro Cordless Clippers I took the blade off, sm. long black plastic piece fell off. Wanted to change blade to ceramic. Can't get it back together don't know where black piece goes. Don't know...
The plastic piece is a blade guide and has a slot down the length of it which the spring locates into. Simply slide the replacement ceramic cutter under the spring
Sep 29, 2009 | Oster 76076-010 Hair Trimmer
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
743 people viewed this question
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Mohamed Ismail
Mohamed Ismail
Falling star
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
