Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I have replaced a printhead and printer worked for a short while
I need to get another printhead, because my printer is not letting the black ink out of the cartridge once again. I've only had my printer for a year, and I'm needing to replace the printhead again. What can I do to keep from having to replace the printhead and where do I purchase a new printhead now that my printer is out of warranty?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I think your sub tank black ink have problem , so if you put a head again ,it will be repeat again,....to be careful
Posted on Oct 10, 2011
  • 45 Answers
Call Kodak for a new printhead. They are aware of the problem.
Posted on Dec 22, 2008
Why won't my printer print black with all new cartridges?
Remove all inks, then the printhead & sit the printhead on a soft cloth soaked in warm water - let it sit for a few minutes then reinstall, close lid then make the machine ask for the inks once the inks have then been installed it should prime the machine. If this does not work try it again & if that fails then your printhead probably needs to be replaced.
Aug 12, 2014 | HP PHOTOSMART PLUS B209A All-In-One...
You just sent me a replacement printer and the instructions asked me to remove the printhead. I do not get insturctions on how to do this by going rto www.kodak.com/go/printheadsupport. I have removed...
Well, I don't think FixYa sent you the new replacement, but it was supposed to be sent by Kodak I guess. Anyway, here's the instructions on how to remove/install or in other words, how to replace the printhead.
  1. Verify that the printer is turned on and there are no error conditions.
  2. Open the printer access door and allow the printhead carriage to move to the center position.
  3. Remove the black and color ink cartridges.
  4. Disconnect the printhead by pressing the button in the upper-left corner of the carriage, then remove the printhead.nonontech_386.jpg
  5. Insert the printhead into the carriage.
  6. Place your thumb over the target label and push in firmly with your right thumb until you hear a loud snap.
  8. Insert the color ink cartridge into the printhead.
  9. Press down on the color ink cartridge until you hear it click into position.
  10. Repeat Steps 8-9 for the black ink cartridge.
  11. Close the printhead access door.
*Follow upto step 5 to remove the printhead, I just included the remaining steps for your information.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Nozzle test does not show pattern for either BLACK output; deep clean does not correct problem. both catridges have plenty ink. color displays are ok.
CANON MP780 BLACK DOES NOT PRINT
This is what works for me. Try at your own risk. I cleaned both areas.
CLEAN PRINTHEAD:
Perform a nozzle check using the Canon software under "maintenance." If the nozzle check prints successfully, the problem is most likely not with the printhead. Otherwise, 1) Lift up the lever above the ink cartridges. Take the ink cartridges out. Put them in a plastic zip lock bag. 2) The container in which the ink cartridges sit is removable. The container is inside the moving mechanism. The container is the printhead. Tilt it slightly and pull up. This should come out easily. 3) There are round pads under which the ink cartridges sit in the printhead you removed. The large one is black. On the underside of the printhead are small slits. The **** separated from the others is black. Fill a syringe with Windex. a. Run warm water over the printhead until no more ink comes out. b. Fill the areas where the round pads are with Windex. c. Set the printhead on some paper towels. The liquid will soak through and come out the underside along with the ink. Repeat steps a-c until no more ink comes out, but at least 10 times. 4) Let the print head sit and dry for two hours. Put everything back in the printer. Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
CLEAN PURGE MECHANISM:
You will need a light. 1) Unplug the printer and move the printhead all the way to the left. On the far right are two rectangular basins. The smaller one is black. Take your fingernail or a tweezers and lift out the sponge pad (do not drop it). Soak the sponge pad in Windex until it turns white. Plug in the printer. 2) Fill a syringe with Windex. a. Fill the basin with liquid. b. Let it soak for 5 minutes. c. Turn the printer off. d. Turn the printer on. Repeat steps a-d until you see a small hole in the basin. e. Put the syringe over the hole and fill the basin, pushing the liquid into the hole. f. Let it soak for 5 minutes. g. Turn the printer off. h. Turn the printer on. Repeat steps e-h 5 to 10 times. 3) Put the sponge pad back in using your fingers (do not drop it). Unplug the printer. Plug in the printer. Turn the printer off. Turn the printer on. Do a clean cycle.
Nov 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a Brother MFC 790cw that does not print black all the other colors work, I have updated the driver bought a new ink cartrige and used the the clean option for the black ink. I know it is recieving...
Try printing a rest page and if that doesn't print in black ink the printhead is probably blocked.
With some printers the printhead is part of the ink cartridge and such problems tend to disappear when the cartridge is replaced, unless the cartridge is faulty. Other printers use cartridges that are ink and nothing more and those are prone to the printheads drying out and becoming blocked unless they are never allowed to become completely empty of ink and are kept in frequent use.
Cleaning/replacing such a printhead usually needs special tools and experience and in the case of many cheap domestic printers the cost of service far outweighs the cost of replacement.
Aug 13, 2017 | Brother MFC790cw All-In-One InkJet Printer
My office jet L7590 printer suddenly quit on me. It keeps playing a message that says the printhead has a problem
Did you let one of your inks run dry? If so, you need to replace the effected printhead. This model has two, one for black and yellow, and a second for cyan and magenta. If you let the yellow run dry but have tons of black, it still effects the black/yellow printhead. Same with the other, either color going dry makes its printhead go bad. Either printhead will set you back about $75. Easy to remove and replace once you get the new printhead.
Bottom line with this model of printer...DON'T let you inks run dry. A new ink cartridge is $20 vs. $75 for a new printhead.
FYI - This is the most common mistake/problem with this printer. The Inkheads are built to last at least 40,000 prints. That's several years for most of us, that is unless you let the inks run dry.
Feb 09, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 Printer
Close the printer.
Aug 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black ink non-printing
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Close the printer.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Aug 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
The black ink cartridge on my kodak easy share 5300 appears to be faulty. I have changed the cartridge and deep cleaned the print head as wel, any suggestions?
Depending on the issue, the solution may be just to replace the ink cartridge. If that does not work, try these steps:
Close the printer.
Jul 19, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
54 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
