Question about Kenmore 44832 Front Load Washer
Brown goo in top loading washer
I have a top loading Kenmore washing machine. I keep getting brown goo inside the tub and then on my clothes. I use Iron Out and it seems to be better but always comes back. What would be causing it and how do I finally get rid of it?
  • 35 Answers
I had exactly the same problem a few years ago. I thought it was a leak from an oil seal and had technicians out. The problem was that I used the wrong washing powder. Find out from the manufacturer what washing powder you need to use and use only that.
Posted on Dec 21, 2008
Small brown particles are found in filter and also what appeaars to be small grease stains on clothing what could be the problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
if it's appearing on whites mainly (hot cycle)...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa
Feb 07, 2011 | LG WFT1071TP Top Load Washer
Hi. I have a Kenmore Elite top-loading washer and in every wash load there are flakes of brown stuff, not rust but more like leaves. There does not seem to be anything wrong with the outflow. Thanks!
Run a few washes of rags or towels with plenty of BLEACH & VINEGAR (two quarts of white) a couple of times to remove most bacterial debris from your machine. There is no part of the machine that "creates" brown flakes, so it is either in the water inflow (check the water) and the way to see what is coming into the machine is to do a "load" without any clothes! Just have the tub fill and look at what fills.....Sounds like something under the tubs upper lip that's coming-off and into your tub during the wash and agitation cycles.
Oct 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
HAVE BROWN SPOTS ON CLOTHING AFTER WASHING THEM. THE CLOTHES GET PUT IN THE DRYER & SPOTS ARE HARD TO GET OUT.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I get brown streak type stains on my clothes regularly. They are about 1 to 3 inches long and orange-brown in color. They are very difficult to remove. I have a 5 year old Kenmore Elite top loading...
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
BROWN GREASY RESIDUE LEFT IN BOTTOM AND TOP OF TUB
could be the transmission shaft rubber seal...need to call service tech for more help thee.
Apr 07, 2009 | Frigidaire GLWS1233A Top Load Washer
Kenmore fornt load washer
Jan 18, 2009 | Kenmore 46462 Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore 44832 Front Load Washer Logo
172 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
