Question about JVC GR-D250 Mini DV Digital Camcorder
PROBLEMS WITH USING MY CAMERA
I'M HAVING PROBLEMS WITH MY CAMCORDER. WHEN I TURN IT ON THE SREEN SAYS UNIT IN SAFEGUARD THEN ITS SAYS REMOVE AND REATTACH BATTERY
Hi. could be wrong, but eject the cassette, on the top there is this tiny yellow (maybe red) plastic switch. should see save or rec with direction arrow. slide it into rec mode and wah-la! i hope!
Posted on May 17, 2007
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
SUBJ: JVC CAMCORDER DVL805. Error message...
oh me MINE did that exact same thing UNIT IN SAFEGUARD.. grrrrrrrrrrr.. YEP NEW CAMERA TIME.. sometimes they tell you that those battery cahrgers will work but it all really just defects them
Jun 11, 2009 | JVC Cybercam GR-DVL805 Mini DV Digital...
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Safeguard mode
Eject tape compartment and let it open, remove battery and blow hot air by hair-dryer from 8 inch distance for 8-10 minutes and attach battery and check camera works fine?
Feb 10, 2009 | JVC GR-D73AG Mini DV Digital Camcorder
Unit in safeguard mode
I found the solution on another web site. You just eject the tape, and then give the camera a few sound whacks near the microphone (I tapped mine of a carpetted floor). Believe it or not this seems to work! My camera had been in "safe mode" for over a year without any success in fixing it. I tried the above method having lost all hope of ever using it again, and presto, the think came back to life! Can't say how long it will last, but at least it's out of safe mode;-)
Dec 16, 2008 | JVC GR-D31EK Mini DV Digital Camcorder
E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Dec 03, 2007 | Video Cameras
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
