Question about BenQ T701 TFT 17" LCD Monitor
Hi, I have a quick question about my monitor. I have a Benq T701 LCD monitor, I think, and it is not using the bottom inch of the screen or the top 1/2 inch of the screen. How can I reset it to factory settings? (It also made the background black instead of the image I had it set as when I tried to change the resolution) Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 21 Answers
Should have reset to factory settings in the display menu under settings.
Posted on Oct 29, 2017
SOURCE: Benq T701 LCD monitor
2SC5707 x4 (lamp driver transistor)....
Posted on Oct 26, 2007
djnupi
  • 26 Answers
SOURCE: benq t701 flat screen no display
see this post
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Posted on Dec 16, 2007
SOURCE: Benq T701 Monitor not display
the video converter is brock
Posted on Sep 09, 2008
SOURCE: BenQ FP731 17" LCD Monitor Problem
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
freetek
  • 5569 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
While playing games the screen refreshes and with a message none present mode! how to i fix this problem?
set the resolution in the game in settings tab to little less then what it is in now
thanks
Dec 05, 2010 | BenQ T701 TFT 17" LCD Monitor
I can't get the screen up. I see its plugged in
Does it work with Desk top PC OK?
When you use it with laptop, you need to use Fn key and either F4,5,6, or 7 depends on your laptop to select how the display will work: both, extenal ony, internal. Please post back.
http://s807.photobucket.com/home/budm/allalbums
Apr 22, 2010 | BenQ T701 TFT 17" LCD Monitor
I brought my benq t701 to a repair shop to due blackout screen. But due to lack of parts, it was not repaired but all 6 transistors were removed from the PCB. Please show me where these transistors were...
go to esservice.com and get the manual from there will be easier as the transistors are directional i believe they are 2sc5707s from memory but you will need to check the transformers and the 2 filter caps on either side of them as if they are faulty will blow transistors.
Dec 30, 2009 | BenQ T701 TFT 17" LCD Monitor
I have a benq t701 with power problems
faulty power board... possibly caused by blown capacitors..
Jul 03, 2009 | BenQ T701 TFT 17" LCD Monitor
Tech problem
If you can, check the display settings.
Some graphics cards have an option for dual monitors.
Sounds like the card is seeing only 'monitor 2'.
If you have more than one monitor port, try plugging both monitors in.
If no luck, you may have to boot into BIOS at power-up and configure from the menu.
But be careful not to fiddle with unknown settings in BIOS - this is the 'nerve center' of the computer and could cause total digital catastrophe.
If not sure, don't.
Or get expert to help re-configure.
Aug 05, 2017 | BenQ T701 TFT 17" LCD Monitor
Monitor's led shows but no screen
Tyler,
Check if there any bulged on top of each capacitors ( caps look like tiny battery) and replaced those caps... If not sure, just replaced all the capacitors. Have fun!
Oct 04, 2008 | BenQ T904 19" LCD Monitor
BENQ MONITOR
I will assume the line goes from top to bottom and is straight.
If so bad news I am affraid. It is the driver tabs that go from the panel to the physical panel controller board and is not making correct contact.
This will normally continue to get worse until you lose entire bands of the screen.
Sorry for the nad news.
Dec 13, 2007 | BenQ FP767 17" LCD Monitor
I had a similar problem: the backlight on my Benq T701 only functioned for a couple of seconds every time a turned the monitor on and then the backlight switched off (sometimes in two stages). An electronics guru at work said with those symptoms the transistors rarely were the problem and I just needed to resolder the connections of the high voltage coils onto the PCB. On visual inspection those solder connections seemed ok, but when I tried to reflow the existing solder at one connection I spotted the problem: just a thin surface layer of solder was present and I had to add solder to fix the problem. The 4 coils each have 6 leads on one side and 2 on the other. I only soldered the connections on the side with 2 leads. In just 30 minutes and without buying parts the monitor is now up and running again.
Jun 23, 2007 | BenQ T701 TFT 17" LCD Monitor
Benq t701 flat screen no display
see this post
Apr 15, 2007 | BenQ T701 TFT 17" LCD Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
75 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
