Back to:
Tags:
V, Inc. V, Inc. VIZIO RP56 Rear Projection Television
Audio does not match video in my new TV, what do i... (by 2 users)
By paulrmc - usenet poster
Audio does not match video in my new TV, what do i need to look for?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 27, 2007
audio and video are out of sync at times
Best Solution
posted on Aug 08, 2005
Helpful (85)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If audio does not match video, check the SAP settings on your equipment and make sure that they are set correctly. Refer to your owner's manual for information on SAP
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Audio does not match video in my new TV, what do i need to look for?:
I don't want to Accept this solution
Solution #2
posted on Mar 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
check GAME MODE under your settings. there is a slight delay with the picture. turn GAME MODE on and it should get them syncd
Thank You!
Solution #3
posted on Dec 16, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
I saw this problem when i bought my new Samsung RP DLP. I hade to go into my AV reciever and add a delay to the audio. If you have dishTV they have an option to match audio to video, but I havent had to use it.
Thank You!
Solution #4
posted on Mar 04, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Just do has they told you and everything will come out perfect.
Thank you so much. You saved us big bucks!!!!!
Thank You!
Can you Help with these Projection Televisions problems?
V, Inc. V, Inc. VIZIO RP56 Rear Projection...
My vizio keeps on turning off by itself. The sound comes...
We have an older tv that works perfectly except when...
I need the remote control codes for a vivitek t.v. the...
I have a 56" Vizio DLP about three years old. It has...
My tv will turn on but I have no sound or picture just...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
