Question about Honeywell Heating & Cooling
Furnace does not fireup - Honeywell Heating & Cooling
  • 334 Answers
Replace the pressure switch.
Posted on Dec 21, 2008
I need driver software for Mac
Do you have disc
Does Mac fireup
If fires up then suggest you upgrade if you have you should have left copy on Mac, just reload.
Jan 27, 2013 | SimpleTech Simpledrive Computers &...
Blower work, but not fireup,red light not blinking any one have any idea what is going on ?
Unplug the ignitor quick connect and check it for continuity. If it checks good then fire up the furnace and see if the power is getting to the ignitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 03, 2011 | Goodman GMS90703BXA Heater
Truck turns over but want fireup replaced fuel pump, fuel pump regulator,coil, tps, etc.
If you have fuel then your problem is obviously having to do with ignition. Plugs, wires, and distributor cap is where I would begin.
Apr 13, 2011 | GMC Sierra 1500 Cars & Trucks
Does not fireup
gregorypatin,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get the parts to fix it and how to do the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 15 yr old armstrong furnace, it wont lite all the time on first try,repair man has replace the smartvalve,igniter and the sensor, the enducer motor comes on then igniter gets brite orange then it...
Has your repairman checked the pressure switch that senses when the inducer is running? Often times when this happens it is the pressure switch or there is something like water in the exhaust piping that will keep it from working. Go to the outside of the exhaust, if you hear water gurgling than you have a problem there. Make sure that the intkae air pipe is clear if you have one. It is okay to pull if off at the furnace tempoarily to see if it works without it.Check the small hoses going to the pressure switch to see if there is any water in one of them.
Just some other things that you can check to see if you can find the problem. It really should lite off on the first try, but yes, it wil try three times before locking out.
Heatman101
Jan 13, 2010 | Heating & Cooling
Changed alternator now car wont start.it will turn over but will not run.checked spark plug wires and the spark is really weak.
changed alternator on my renault espace, it started but cut out after a few seconds. Now it will not re-start (fireup )
Sep 16, 2009 | Buick Park Avenue Cars & Trucks
Toyota rav 4 turbo diesel 2003 hard to start when warm.
plenty power in battery turns over well just hard to fireup have checked heater plugs as you would think they were not working but they are ok even hard to start when warm after long drive say you stopped and went into shop for paper came out just the same hard to fireup
Aug 03, 2009 | Toyota RAV4 Cars & Trucks
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
My gas dryer heats at the start but dont reheat up
remember if it glows and shuts off w/out turning on heat replace both gas coils,, than kyou
Dec 27, 2008 | Kenmore 73932 Gas Dryer
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
