Question about GE Profile JTP56 Electric Double Oven
Changed the lite bulb on ge double ge eletric oven and it blew
The lite bulb spark rteand blew out the power, cant find the breaker or the reset switch on the oven
    Sergeant:
    Champion:
  • 338 Answers
There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
Posted on Dec 21, 2008
Why oven not heating
Bad element, bad switch or other electrical problem. You could double check switch by turning on broiler element to see if that
gets hot. If so then either oven thermostat, or element. Did the circuit breaker pop off and then you reset? So there is a short somewhere, especially if it happens again. The above test with broiler element could verify power to oven. If it pops the
circuit breaker again. You need a service technician. Usually the oven requires a dedicated wire to the oven. Don't use the oven again until the problem is resolved. There's a slim possibility
that the circuit breaker needs to be replaced. How long did you use the oven? If a long time circuit breaker is more likely because
when they begin to fail they get too hot and therefore pop. You will need an electrician to change the circuit breaker if that is the problem.
Feb 13, 2015 | GE JKP90 Electric Double Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | GE JKP45 Electric Double Oven
Display screen wont turn on. Breaker was not tripped. cant ge them the screen to turn back on. irst time the problem came up. They havebeen working great until today.
Do the oven work at all, if it does not you will need to turn the breaker off and back on, it may need to be reset, it will appear fine but it will indeed need to be reset.
Nov 14, 2009 | GE JKP27 Electric Double Oven
Fuse location
are you talking about the breakers that are outside or in the garage? Look where the main power goes into the building and there is where the breaker for the oven should be.
Dec 24, 2008 | GE Profile JT952 Electric Double Oven
Ge double oven - both ovens stopped heating gradually
My first thought is the power supply to the unit.  Cut the breakers and inspect all connections from the fuse box to the oven.  You will likely find open connections or corrosion.  One breaker could also be bad.  Check the voltage with appropriate caution and a voltmeter.  Breakers should respond with a snap when turned on.
Note: there are two breakers which control the oven: one with a red wire, the other is black.  Each provides 110 volts to the oven in combination with the white neutral.  Together, the black and red give you 220.  If one of the circuits is out or in poor condition, the bulbs might not work and the oven won't either.
Dec 04, 2008 | GE JKP28 Electric Double Oven
GE Oven Model JK1901BC
check power cord if oven light not working or burners then you have a power problem no there is no reset if you have power at the outlet then pull the range out take off the back cover where the power cord is and check there let me know we will go from there
Dec 30, 2007 | Ovens
GE Profile JTP56 Electric Double Oven Logo
149 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Steve Allison
Steve Allison
Are you a GE Oven Expert? Answer questions, earn points and help others
