Question about Panasonic PT-47WX49 47" Rear Projection Television
Horizontal lines on start up
Hi, when we first turn the tv on and for about the first half hour there are horizontal lines distorting the picture. it has been going on for about a year now and has gotten progressivly worse..more lines and longer duration. the set is about 6 years old and when it is fully "warmed" up has a great picture, expecially in high def. any ideas??
  • stephen van winkle Apr 04, 2007
    yea i dont know about lightning since we have ours on a surge protector. i was figuring it might be a transformer getting weaker with time but i dont even know if thoes are in the set.im thinking it has to be a power supply problem because the picture is great once the set has been on for awhile.
  • Anonymous Nov 15, 2007
    Yes, I have the same issue and looking for a solution. any help would sure be great.
I get the exact same issue, exepct now it never clears up. I have tried to find someone to come look at it but no one does "house calls" anymore and everyone I call makes it sound so easy to just toss this beast in a car and bring it in. One of the repair techs said the issue sounded like the board had been zapped by a lighting surge...but of course there was no way to be sure unless I brought the set in.
Posted on Apr 03, 2007
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have a Samsung DLP HLN 5065W and recently the TV started to get Horizontal Lines in it with a 2 inch black horizontal line across the TV and the bottom half you could see the picture and the top half...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Samsung HL-R6168W 61" HDTV
My RCA F36648 36" TV has only the bottom half of my picture working. The top half has horizontal lines that distorte the picture. It looks like when you pull a rake through the sand the lines that are left...
You have vertical output problems.There is distortion at the top because of a faulty vert. output i.c. or a faulty electrolytic capacitor.It's possible there may be a problem at your yoke also.It needs a professional repair.
Sep 29, 2009 | RCA F36648 36" TV
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
