Question about Brother ML-100 Typewriter
Problem: Typewriter isn't typing any letters on the paper.
Letters will not type on the paper.
Is the platon properly seated? Sometimes the platon (the rubber tube thing that you crank the paper around) has been removed and then not returned all the way down into its cradle. Try pushing both sides down with equal pressure and see if it drops down and tightens. Good luck!
Posted on May 09, 2007
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
Letters i type on key board come up as different letters on paper. example if i type the word see, it comes up and types j;;.
On the L. side of the keyboard is the pitch slide switch it should be in 10 or 12 not PS.
DickyO
Aug 16, 2011 | Swintec 7040 Typewriter
I have an Olivetti Lettera 32. I put a brand new ribbon in it and when I type, the letters are coming up too light on the paper. How do I fix this? What needs to be done?
First thing is to be sure the ribbon is feeding, watch while you type. if not you may have a universal spool ribbon that isn't quite that universal. Wind the ribbon onto your old spools.
DickyO
Jun 06, 2011 | Olivetti Lettera 35 L Typewriter
The typewriter is not displaying the numbers or letters that I want to type. How do I reset the machine?
If it isn't in in KBII oe a language mode the Print wheel homing pawl nis probably broken.
DickyO
May 24, 2011 | Brother GX-6750 Typewriter
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
I have a smith corona sd680 work processor typewriter. When I type the letter don't come out clear and I have to type over and over in order to read the letters. This is an old typewriter in the office...
This problem is usually caused by an old ribbon theey do dry out when left in tthe typewriter a long time, also if the paper is really hard or has a slick surface the ink from the ribbon will not stick to the paper.
Dec 14, 2010 | Smith Corona Office Equipment & Supplies
I am trying to type on labels but I cannot get the typewriter to grab the paper, so I keep typing on top of the same letters. When I hit return, the paper moves with the typing part.
If it works on paper Then take a pice of 150 grit sandpaper and remove the glaze on the platen. After you will have to wipe the platen to get the black dust off.
DickyO
Oct 18, 2010 | Swintec 7040 Typewriter
The keys don't type the correct letter
Loosen the screws that hold the silver guide, one on each side of the carriage. Adjust to touch platen with 2 sheets of paper installed. When you reset next time it will reset to the right letters.
Jul 01, 2009 | Brother GX-6750 Typewriter
Will not type
The print solenoid plplunger pad is probably broken. They are available fron us for 15.00 but a little tricky to install.
DickyO
Dec 10, 2008 | Lexmark Wheelwriter 3500 Typewriter
Brother ML-100 Typewriter Logo
81 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
