Question about Syntax Olevia 432V 32 in. LCD Television
Olevia 432 S-12 Component Shows no signal with cables plugged in.
I just recently got some component cables for my ps2 and plugged them into my Olevia 432 S-12 and It's telling me that there is no signal. I tried before with my friends xbox 360 a while back and couldn't get it to work and thought maybe it were the cables but now that I have my own, it still doesn't seem to work. I'm wondering if maybe my TV is a faulty unit or if there is anything i can do to either fix it myself or firmware i could upgrade to maybe fix the situation.
It came as a refurbished unit off of a website that had a crazy deal on the TV and it works fine otherwise, HDMI and all other things seem to work. I haven't had any problems with this TV besides the component situation. Any help would be much appreciated.
  • 1 more comment
  • Anonymous Feb 07, 2009
    I don't think s-video would not work, since it uses the RCA slots plus just the s-video slot. I'm more interested in actually getting the component to work for when I obtain a PS3 so that I'm not stuck with dirty quality graphics due to the TV lol.
    Thanks for the help though, is there anything else that might be causing the component to not be working anyone?
  • oathsoblivio Feb 07, 2009
  • Anonymous Feb 22, 2009
    Tenemos el tv Modelo Olevia 432 s12, Estamos en Colombia y tenemos problemas con la señal de cable, hemos seguido el manual para configurarlo pero no solucionamos el problema de señal.
    Por favor repondernos en español al correo
    sofi1322@hotmail.com
  • 3 Answers
Have you tried an S-Video cable with the mode set to Standard Def. TV?
Books
Posted on Feb 03, 2009
I have an RCA Remote that turns on Olevia tv but won't find a signal and neither does the tv remote. I'm on cable.
perhaps you need to set it on channel 3 for the cable to work .. the cable box must be on when doing any searching also
Jan 19, 2015 | Olevia LT42HVi 42 in. LCD Television
What channel do I need to go on to play my playstation 2 on a Toshiba REGZA television?
The channel can be either Aux if you use the Yellow, Red, White(composite) those are what the PS2 came stock. If you Used the RF modulator to hook it up using coaxil cable then its channel 3 or 4 depending which you have it set and If you bought the component cable(so you can take advantage of 480p for the dvd player) then it will be the channel labeled component. Just a note if you do use the last cable(component) I mentioned you will not be to play Playstation 1 (PS2 backwords compatible) games because they are not able to be viewed in 480p.
Dec 15, 2010 | Olevia LT26HVX 26 in. LCD Television
Component input
If you are only getting a black and whiite image, that means you're only getting the luminance portion of the signal through your cables. You either have the Xbox connected wrong, or you have bad cables.
Nov 29, 2009 | Olevia LT26HVX 26 in. LCD Television
How to hook up a game console to an Olevia 232-T12
It all depends on your game console.
You can connect most to the Component, Composite, or HDMI inputs.
For modern consoles, use HDMI cables or provided Composite cables.
HDMI = Single cable and single plug (Best)
Component = Red, Green, Blue, Red, and White plugs (Average)
Composite = Yellow, Red, and White plugs (Worst, used for most older consoles and older TVs)
Nov 25, 2009 | Televison & Video
How can I set up the Playstation 2 to the TV with
ok samsung is partially right you might have paid for bad cables
but on the other hand you will get a better picture with the component
but all you have to do to have those cables work is plug the colors in the back of the tv so they match and then select the port that it is plugged into make sure the console is on
on some of the older ps2 you did have to go into the options menu to change your display options but if thats the case its self explainitory
hope this helpd
Oct 31, 2009 | Sony PlayStation 2 (PS2) Console
My Olevia Model 427-S11 shows "no signal"
Silly suggestion, but did you hit the "Source" button again a few times?
According to the manual, the "Source" button changes between the following long list of options:
Tuner, Composite, S-Video, Component, HDMI, VGA, and VGA component.
So you'll have to hit it 6 more times to come back to what you were using.
Olevia went out of business in 2008, so their website is defunct. Here is a link to what I believe is your manual on another website.
http://www.retrevo.com/support/Olevia-427V-TVs-manual/id/563ci863/t/2/
Sep 07, 2009 | Televison & Video
I have an Olevia 23t lct hd tv. I am plugged in
you said you are using composite cables..? that means you have some kind of cable box ? if you want to get HD channels you have to use a HD box that is supplied by the cable company.. the HD cable box then has to connect to the tv with component cables (green,blue, red cables) or HDMI cable.. to send the HD signal to the television.
May 13, 2009 | Olevia 237T 37 in. LCD TV
No video display,
UUUHH HHHH DUH!!ITS NOT MENT 4 PS2!!!
Jan 26, 2009 | Sony Playstation 3 (PS3) Console
Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Oct 03, 2008 | Panasonic Televison & Video
Syntax Olevia 432V 32 in. LCD Television Logo
855 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Jose Pino
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
