Question about Golden Technologies Compass Electric Wheelchair
Charging batteries Batteries charged unit will not operate. We would like a manual. Is there a switch to turn on power other than on the joy stick? Please reply as soon as possible. We were told to charge up the batteries which we did for approximately 5 hrs.
    Problem Solver:
  • 8 Answers
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life
Posted on Jun 11, 2009
My Invacare Wheelchair w/tilt & recline doesn't fully charge. I'm on the third new battery change & still same issue. Could it be my circuit board. Could it be me joy stick?
In any device that has a charging circuit that circuit can fail to charge batteries after a time. Ypu could have an electronics technician check what happens in the charging circuit. As you have changed three batteries the fault must lie elsewhere, as you have deduced.
Support Surface Resources
Support Surfaces
Jul 04, 2015 | Invacare Health & Beauty
I have a jazzy Select GT power scooter, on the charger I have a red light and green, I put it on charge and have both green lights on now but the controls near the joy stick and on and off light nothi
need more info on equipment to answer ,scooters dont have joystics powerchairs use joysticks if you have a powerchair that has not been charged for over two weeks the batteries have probably died
in this state the charger will not go into charge mode only the power light and poss the fully charge lights will light
as a quick test a 24 volt bulb from a scooter or lorry with 2 wires attached pushed into the two outer holes in the joystick charge socket should light up if it wont batteries are totally dead
Nov 21, 2014 | Health & Beauty
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
Why does joystick light drop to red as soon as u move motor were done new cable and joy stick
The batteries are to weak to drive the chair. It takes a lot of battery power to start moving but not when you just turn it on. Using a volt meter in the charge port before and when you push the joystick will confirm this. Very typical of wheelchair batteries to do this when weak.
Sep 09, 2014 | Health & Beauty
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
Does my Hoveround need to be on or off when I plug it into the battery? Does it need to be on so that the lights show up on the joy stick or do you turn the chair completely off and then plug in the...
Either way will work when charging the batteries and it wion't hurt the chair either way. If you can stand to have the lights scrolling all night when you charge the chair then leave it on If not turn the power off Your charger will tell you when its finished by turning the yellow light green. Hope this helps
Nov 11, 2010 | NRS Hoveround MPV 5 - Used Power...
Just bought sed Jazzy Select for my wife. Chair appears relatively new. No leakage or corrosion on batteries. Charger indicates full charge but within two minutes of operation both green lights on joy...
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
Oct 24, 2010 | Pride Mobility Products Jazzy Select
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I just received my new uniden scanner,and I am having problems with charging the radio. I was wondering do I have to have batteries in it ,to charge it with the dc that came along with the radio. How do I...
The BC72XLT is a battery-operated scanner, and your power supply is a battery charger, not a battery eliminator. You must have batteries in the unit for it to operate. You can install rechargeable batteries and use it in conjunction with the power supply, or you can run it on non-chargeable alkaline batteries.
Mar 21, 2009 | Uniden BC72XLT Handheld Scanner
Golden Technologies Compass Electric Wheelchair Logo
283 people viewed this question
Top Golden Technologies Health & Beauty Experts
Rob Hill
Rob Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
