Question about SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
I just got my Sandisk Sansa e260 last week. I completed loaded my songs through MSC mode last night. I was listening to it all morning and when I went to FF to another song the screen disolved into a blank grey screen. The screen is back lit and blank. The sansa will not do anything. I cannot turn it on or turn it off. Its not playing anything. I'm not sure what to do. I didn't get a low battery message or anything.
  • 3 Answers
U have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Posted on Apr 04, 2007
My Sandisk Clip 4gb player kee[s showing me the not enough space messgae. Can i reset it without deleting my music?
For this issue, the reason why you're receiving this message is that some of the songs that are loaded on your Sansa is already corrupted and the only way you can resolve this is to format the MP3 player. This is a known issue with this particular player, specially if your combining the MTP mode and the MSC mode. MTP mode is your device will show as a Multimedia device under your computer and allows you syncronize your songs using Windows Media player . MSC (Mass Storage Class) mode lets you drag and drop songs directly to the player under windows explorer just like a flash drive.
Jul 04, 2011 | SanDisk Sansa e260 MP3 Player
Song Removal
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Make sure you have it in MSC usb mode
Download and install run connect sansa when asked. Link
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
This has the manual also
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
How to load songs on the player
1 Check to see that the player is in MSC mode by going to the USB mode section in the Settings menu.
Step2 Plug the SanDisk Sansa MP3 player into your computer.
Step3 Click on the Start menu.
Step4 Click on My Computer.
Step5 You will now see a drive for the device and one for the SD card.
Step6 Double click on the Sansa device.
Step7 Go to the My Music folder or the location of your music files.
Step8 Choose songs from your folder and drag and drop them to your Sansa device.
I hope that helps..
Please rate accordingly
Thank you
Computerrep
Jan 27, 2009 | SanDisk Sansa e260 MP3 Player
E260 - now showing two empty directories (but I still have my music)
try formatting it. to do that, simply scroll down to settings, and in settings hit format. you'll lose everything that was on it tho, if that don't work then try updating. if your unsure how to update go here.
and install the program.
Nov 06, 2008 | SanDisk Sansa e260 MP3 Player
Frozzen on Refresh Database
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 13, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa e260 MP3 player is not working properly.
try changing to msc mode. go to settings and then usb mode
it has to be on msc mode to show up as a removable hardware
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
Refurib - sansa e260 - need vista driver
Go to settings, usb mode and change it to msc. Then it will show up as a drive and you can drag songs to your music folder. I just updated my firmwareand now it's loading in MTP mode so Windows Media Player can load it etc.
Apr 21, 2008 | SanDisk Sansa e250 MP3 Player
change the mode of the player to MSC from Mtp MODE AND SEE
GO TO SETUP AND ENTER usb MODE AND SELECT msc I THINK THAT SHOULD solve your problem
Jan 24, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 keeps connecting/disconnecting
start by updating the firmware to the latest version. You can get the firmware updater (you will have to do this on your brother's computer probably) online at sandisk's site. Then, check back in after you've done that-sometimes more problems arise, sometimes problems are fixed.
Dec 13, 2007 | SanDisk Sansa e200 MP3 Player
Pink Screen says "No Song"
Hi. It would seem that either the internal memory of your player has been corrupted or the firmware has experienced some errors. The best way to fix your player would be to either format it or re-load its firmware. Either way, you may need to re-load your music files once again. First, you would need to set your player to MSC mode by navigating the menu as follows: Menu >> Settings >> USB Mode, then select "MSC". If you have the "Rhapsody" E200 version, then select "Rhapsody" (it's the same as "MSC" mode) Next, plug your player in your computer and look for the drive letter corresponding to your Sansa. Right-click on the drive letter, then select "Format". Just make sure that the File System is set to FAT32. Click "Start" to begin the Format and follow the on-screen prompts. Since your songs came from audio CD, simply Drag-and-drop the files to your player (MSC mode is will actually work best with audio CD songs) If this does not work, then go ahead and re-load your Firmmware using this instruction I received from SanDisk technical support: Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would restore your player to normal settings.
May 16, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
211 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
