Question about Bose 3·2·1 II System
Dvd password accidentally entered How do I reset?
A password was entered and now I can't play dvds without entering a code can the system be reset
I just had the same problem tonight. My wife figured it out. The system password is 'BOSE', which is 2673 from the telephone keypad. Enter 2673 and this will unlock the default system password. My old 321 system also lost it's FM presets, so I think the original CMOS battery died on it's motherboard.
Posted on Dec 26, 2008
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
I bought a used playstation2 andit had a parental password.How do I get the password off so it will play dvds?
-power on
-reset
-inset DVD R rated..(18 up only) when board comes up telling you parental control is on
-hit select
-it will say enter password
-hit select
-it will say delete password
-enter in 7444
-hit X
supply one you will remember, or write it down.
If this doesn't work only unplugging the playstation for 48-72 hours will clear this...
Aug 08, 2009 | Sony PlayStation Portable (PSP) Console
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Password reset
The Rating menu allows you to block playback
of DVDs based on their ratings.
Setting the Password & Rating Level
The DVD player allows you to block playback
of inappropriate content with a passwordprotected
Rating system (not all discs are rated).
A. From Stop mode, press SETUP.
B. Select Rating and press ENTER.
C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
to 8( least restrictive ).
If a password has already been set, the lock icon will be closed. You will not be
able to select Rating until you SELECT the correct password using the 0-9 keys.
D. Select Password.
E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
close to indicate that the rating and password are set.
F. Press SETUP to save and exit.
Not all DVDs are rated.
DVDs that are rated higher than the level you select will not play without SELECTING
the correct password.
If you forget your Rating password, select 8888 to clear the memory. Keep this password
out of reach of children as if will always unlock the Parental Control setting.
If you need more help you can get the full manual from
http://www.retrevo.com
Thanks for using fixya
Aug 01, 2009 | Astar DVD-3800
How can I unlock playstation 2 dvd to be region free?
Step 1
Turn on your PS2 and choose the menu screen where you would normally enter the password. Instead of entering a password, go to the DVD setup menu. Go to "custom setup" and choose "parental controls".
Step 2
When you are asked for the code or password, press the select button on your controller and enter the number "7444". Now set the parental lock to "off".
Step 3
Press "reset" on the front of the game console to save your settings. When the system reboots, you should be able to view your previously censored games or DVDs. You will also have the opportunity to choose your own password, allowing you to turn the parental lock on and off, either manually or automatically by game or movie ratings.
I often recommend that the parents of older children should regularly reset the password in order to prevent "hacking". Also, try to choose a password that could not be guessed easily. Often, a combination of both letters and numbers works best, as the laws of statistics dictate that more choices equal more failed attempts at cracking the code. Unless your child is exceptionally persistent or lucky, boredom will win out before they guess the correct code.
Dec 16, 2008 | Sony PlayStation 2 (PS2) Console
My ps3 is displaying green and purple waving lines and is effecting my games and movies
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
and the contact info is 1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
May 29, 2008 | Video Game Consoles & Games
Ps 3 cant show dvd's
if that does not work then call Sony at
Good Luck,
-Rel
Apr 19, 2008 | Sony Playstation 3 (PS3) Console
PS3 and & DVD's
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
PS3 DVD'S playing
Wont paly dvd's
Bose 3·2·1 II System Logo
1,004 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
