Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwaher doe not drain water - Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
  • 3 more comments
  • Anonymous Dec 28, 2008
    does not drain
  • Anonymous Jan 10, 2009
    wont drain
  • Anonymous Jan 23, 2009
    The washer leaves water in the bottom after a cycle.
  • Anonymous Jan 25, 2009
    i replaced drain line, and still wont drain
  • Anonymous Feb 18, 2009
    My dishwasher has a bad smell when left closed and now the water won't drain. Is there a filter blocked?
  • 42 Answers
You have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed
Posted on Dec 21, 2008
4 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: HELP
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
Daniel S
  • 4323 Answers
SOURCE: my bosch shu9925uc dishwaher will
Hi
After reading your post I don't think it is the control that is bad. If you have already checked the water inlet valve and cleaned the water lines & the valve for any clogs then it is the float switch that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 29, 2010
Daniel S
  • 4323 Answers
SOURCE: Hi my bosch dishwasher is
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Note: Disassembling the dishwasher yourself will void the warranty. Calling Bosch for free repairs is suggested.
To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jan 13, 2011
After cycle standing water remains in the dishwaher
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Bosch Evolution 300 SHE42L1 Built-in...
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Where is the drain screen at in my My frigidaire dishwasher
generic reply normly in the center and looks like a plastic grating, but is your drain hose kinked?
Oct 25, 2008 | Frigidaire Dishwashers
Does not drain water after wash/rinse cycles
check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Sep 04, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwaher
Generally, you need only hot water. It is advisable that the drain line be a little lower than used by a washer. Drains usually go into a modified portion of the sink's j bend in the drain. This sits at about 18 inches off the floor. You should fuse your electric line for 20 amps at 120 volts or 15 amps at 240, depending on your location. North American units are at 120.
Mar 15, 2008 | Dishwashers
Dishwasher problem
there is a float in the tub looks like a little dome or such if its not touching the micro switch under it and pressing down on the leaver then the washer thinks its over filling and will not let the valve turn on remove the lower panel to see if its on the switch if not make sure the water is on then start the washer and see if the valve solenoid is getting power
Dec 30, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore 665 Dishwasher Not Draining
try checking drain lines for the dishwasher for clgs and under the screen in the bottom of the dishwaher
Dec 01, 2007 | Dishwashers
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
162 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
