Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Water leaking from steam wand when brewing shots
Water leaks from steam wand when shots are being made. Doesnt drip any other time
  • mgolbey Jan 16, 2009
    Thanks for trying. My machine must be a bit different - different number of screws to remove case and cam was fixed and not adjustable once I did get the case off
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Posted on Dec 29, 2008
  • philipschrei Dec 18, 2010
    Don't try this if you have 4 screws in the back!!! It is virtually impossible to get to the guts of the knob. Taking apart the housing will result in beans getting everywhere, gears disengaging, and you will have difficulty getting the assembly back together (and I am a mechanical engineer). Just live with the dripping steam nozzle by putting a cup underneath.
Delonghi magnifica leaking water
First I'm not a Delonghi tech. But I have worked on similar table top "Super Automatic" machines. You should call your vendor for service as there is no customer serviceable parts in this machine.
*** the following is for information only. ***
* If your leaking at or under the water tank then check for crack or you may be missing a rubber seal, o-ring, or washer. Replace the whole tank as a unit.
* If your leaking into the dregs or drip tray then there is a problem with the brewing system. Call for service. They may need to replace the brew valve or PC board.
* If your leaking at the bottom, drip tray, or side only when the pump buzzes (pumping water) then there is a cracked or disconnected hose line or fitting. Call for service and replace.
* If your leaking when the steam wand is in use then there is a similar problem with the 2nd pump system. Call for service and replace.
* If your leaking liquid coffee into the dregs tray or drip tray. Then you have a worn or missing group gasket(s). Call for service and replace. (you may find gasket kits from Amazon.com or online.)
* Final; Leaking water and electrical equipment is not a good idea. Best to be safe. Unplug and call for service.
Aloha, ukeboy57
Feb 04, 2018 | DeLonghi Coffee Makers & Espresso Machines
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Gaggia titanium. The water and steam are all going through the brew head instead of coming out the wand when I need it to. I have cleaned everything, used a pin to clean the wand (it didn't need it) ONE...
This is hard to picture. The only way water can come out the brew spout is if the brewing mechanism inside in the position to make coffee. The only way to get that mechanism into that position is to either select one of the three coffee buttons (you'd hear the grinder run, then you'd hear the motor putting the brew mechanism into place and then the pump start and water would then come out the brew spout. OR to select preground coffee and then select one of the three coffee sizes - in that case you wouldn't hear the grinder but you'd still hear the motor turn the brew mechanism into brewing position and then start the pump.
When you simply select hot water and then open the steam valve - I can't imagine any possible way for water to come out the brew spout.
Now if you mean that you don't see any water come out but water is leaking inside the cabinet and ending up in the drip tray - then that would mean a leak inside the machine. It could be the valve that the brew group locks into when it goes into brew position (you see this valve in a little recess behind the brew mechanism when you take the brew group out to clean it). Or it could be a leaking steam valve or hose inside.
You might try getting a flashlight and a cleaning brush - take out the brew mechanism and then clean around that little nozzle/valve that is in the recess just the left of center behind where the brew mechanism was. That valve should shut when you are not in brew position and not allow any water out - but it may be gummed up with coffee grounds.
If you are feeling brave - you would need a deep socket and a lot of patience with a small breaker bar (a ratchet head is too big to fit in there) and you can remove that nozzle/valve and then clean it or replace it. But it is very slow going to remove it (there must be some special tool they use at the factory). I had just the right size deep socket (like what you'd use for a spark plug in a car) but there wasn't room for a ratchet so I had to use a small breaker bar and I could only turn the valve about 1/4 turn at a time then I'd have to reposition the socket to do another 1/4 turn. It took 5-10 minutes to remove it - then it was easy to clean. I think you could clean it in place with a stiff bristle brush and some q-tips.
I don't know if that valve is the problem - but that's the only thing I can think of that would have your hot water and steam running into your drip tray instead of out the steam wand.
Oct 26, 2010 | Gaggia Titanium Espresso Machine
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
It is dripping a little water out of the left head and dripping a little out of the left steam release in the back.
Replace the solenoid on the head and the swivel o-ring on the steam wand, if leak is in the nut, if it is in the handle then the 2 small o-rings on the plunger needs to be replaced.
Dec 01, 2009 | Nuova Simonelli Premier Maxi Espresso...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
1,047 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
