Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
Kenmore side by side w/icemaker extended power outage
I have a Kenmore side by side with icemaker. It must be about 10 years old. Recently we had a storm and were without power for week. I did have a generator, but had problems with it going of and on.
Now that the power is back on everytime the fridge comes on but will not stay on. After a while the GFCI plug that is near by goes out and all power in the kitchen is lost. Once it is reset everything is fine for a while but once the fridge is plugged in again something pops and the fridge goes off. Any suggestions? I need to get food, but I don't want to until I know it is all set.
Jo-Anne Loan
  • 700 Answers
Threre may be something shorted inside of the refrigeratoer because the gfci is tripping out. and or when the compressor tries to come on the start components are weak and it draws too much amperage. Either way you are going to have to call a serveice professional. Thanks For using Fixya. and Merry Xmas!!!
Posted on Dec 21, 2008
Kenmore side by side icemaker not working after power outage, but water at door dispencer
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out. If it is not operating properly it should at least hum and vibrate. If that does not occur your problem lies elsewhere. As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Kenmore Side by Side Refrigerator
Kenmore 52552100 refrigerator not working
Hello.... do you still have the parts??
I can use Part 921526 PC Board kit, emitter & reciever icemaker - $30.
You can email me at durangoboy@xemaps.com
Thanks,
Paul
Oct 09, 2009 | Refrigerators
Not cooling or freezing, can hear the motor running and electricity to getting to it, but melted everything and hot inside. 10 year old side by side icemaker
Hello there..your problem seems to eminate from either a failed compressor...or an internal gas leak....the compressor may be running but unable to pressurise the system....however the most likley cause is an internal gas leak....generally not repairable at 10 yrs old i would advise replacement
regards Sir Galahad
Sep 21, 2009 | Refrigerators
Icemaker dont work after power outage
Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
Let me know what you find.
Jan 30, 2009 | Refrigerators
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore side by side 253.54662400 makes hollow ice cubes - do not dump
yes i would replace the icemaker. it sounds like the heater and ejectors have lost their sync. could be caused by the internal drive motor.
Jun 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Icemaker
check inside the ice maker are the forks pointing up or down if they are down them the module on front of ice maker is broken it needs to be repl, but you said is 8 years ol d so i would repl the whole ice maker since the mold might be peeling off due to age they only last like 4 years or so
Jun 11, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
217 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
