Question about Mitsubishi WS-55819 55" Rear Projection Television
Do not get any local tv stations
Hdtv1080i
  • Ray Smith May 11, 2010
    More information is needed. Did it ever get them? What is your signal source (Antenna? VHF [2-13] or UHF [14 & up]) Cable or Satelite? Make sure the VCR is turned off.
Have you tried to have the tv learn the channels? if yes make sure the input cable works.
Posted on Jan 04, 2009
Wont turn on
Main digital board fault. Check and replace it. In most cases a firmware update too might be necessary. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Samsung Televison & Video
Does this product have a built in digital to analog converter?
This tv incorperates a full digital PLL tuner. It does not need a digital to analog coverter since analog signals is no longer used. All tv stations now broadcast with digital signal. It will receive local broadcast stations just connect a goood quality antenna to the tv. You will need to do a scan and the tv will store all of your local broadcasting stations within range. An outdoor antenna works best for digital signals.
Sep 13, 2012 | Samsung LN32B460 32 in. LCD HDTV
How can my use my centrylink internet modem to mymitsubishi hdtv1080i
Hook your modem into t he LAN connection on your TV. Then in the user menu do an automatic wired setup. This only takes a minute or two and you will be up and running.
May 18, 2012 | Mitsubishi Televison & Video
Can i get regular tv
To get local over the air channels, you will need to connect an antenna as your signal source instead of Cable on the back of the set. Then you will have to go into the TV menu for signal source and select the Antenna/air option. Then you will have to go to the auto program/scan menu and scan in the stations. This may take a few minutes.
Now you can watch local stations for free.
I believe the FCC "must carry" rule require cable to carry local stations also.
Mar 04, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Unable to get stations 17 and 45(UHF)on Zenith model SM2067BT
the problem is station 17 1nd 45 is not yet programmed to your tv...
Sep 11, 2008 | Zenith Televison & Video
Local tv channels come in snowy
you have cable and the stations are still snowy? could be tuner do you have a box or directly hooked up to tv, try unhooking box if you have one and directly hook it up to tv if you havent already done so
Jan 21, 2008 | Zenith C32V37 32" TV
Akai HDTV1080i Monitor
Can you tell us the exact model?
Dec 02, 2007 | Televison & Video
Mitsubishi Medallion HDTV1080i
MY PAWNZ-MOST LIKELY A BAD DM MODULE.THE ESTIMATE ON THOSE SEEMS TO BE ANY WHERE FROM 300-600 BUCKS.MAKE SURE YOU GET A MITSUBUSHI EXPERIENCED TECH.JOE TV
Nov 13, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
