Question about Kenmore 63792 Microwave Oven
How do i change the light bulb in my Kenmore Elite Microwave
I remember seeing a light in there when we bought it but now nothing. I cannot tell how to get to the bulb.
  • Bill Moerdyk Dec 24, 2008
    Thanks for the help. Light is replaced.
  • 35 Answers
If it is like a microwave I had, you have to take the whole cover off. Just make sure it is unplugged before undoing the screws.
Posted on Dec 21, 2008
Why is cooktop light so hot on Kenmore Elite microwave hood combination
Check your owner's manual for the proper wattage bulb, and be sure NOT to exceed it.
Jun 27, 2014 | Kenmore Microwave Ovens
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Where is the internal light bulb in the sears elite microwave convection oven
Hi there, I'm just running out the door, but came across your question after checking my solutions, and thought I'd give you a quick run through on where most lights bulbs on microwaves are usually located. One, they're either on the outer left side of the microwave (look for 4 phillip head screws within a cover approx. 3''wide x 4" long). If not there, then it's located on the top of the oven. Remember, before you remove anything...first, remove the plug from the wall outlet (receptacle) Again, you'll be removing 4 phillip head screws. Then, after removing the top cover (sometimes, you'll have to slide one way or the other, then lift) look again for the 4 phillip head screws within a cover approx. 3" W x 4" L. Remove this cover, unscrew bulb, and then replace with the same bulb. Its best to remove the bulb first, then take it with you to your nearest appliance store. This will help make it easier for the clerk helping you. Then, after you replace and secure all your covers and screws, and are completely done...you can plug your oven back into the wall outlet.  Then turn it on to check and see if your lights back on and in operating order. I wish you the best of luck, and if you have any more questions regarding this matter, feel free to contact me again. Jim
May 21, 2010 | Kenmore 80412 Microwave Oven
Bought a home with a Kenmore UC MV, Model # 721-62643200 Ser # 311KM02070. There were no light bulbs in it, so I bought two GE Indicator 25 T-7 bulbs, for microwave ovens. These bulbs are 25w 120v. Upon...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Kenmore 721.62643200
Dec 25, 2009 | Kenmore Microwave Ovens
Kenmore elite microwave displays F9 after a few seconds
I have the same problem. The sears guy told me that I needed a phillips screw driver and a torx adapter/driver to remove the entire microwave cover ( it slides off0 to gain acess to remove and replace the bulb.
Dec 29, 2008 | Kenmore 63792 Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Kenmore 63792 Microwave Oven Logo
504 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
