Question about Logitech Harmony 550 Remote Control
Everytime i press watch t.v. it goes to welcome
Everytime i press watch t.v. it goes blank then it goes to "welcome to your remote" cable and t.v. are not responding to any commands
Hey... someone else on another site helped me out when I had the same problem. The thing is was that some of my buttons were stuck... check to see if any of your buttons have got caught underneath the remote face. Hope that helps.
Posted on Dec 25, 2008
Philips blueray player not working with lg smart tv
If you press play after welcome screen, you should see picture.
Jan 18, 2018 | Philips Televison & Video
My psp screen goes blank everytime i press the home button.
this is for the tv out function you can buy a cord so you can play your psp games on your tv and holding down this button activates that but you need the cord eb games have it for about 30 dollars
Jun 03, 2010 | Sony PlayStation Portable (PSP) Console
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Screen goes blank momentarily
cover up the infrared remote sensor on the projector. The heat of these colours or something might be messinf with the infrared remote sensor. TRy this and see what happens. It may just be bad contacts. Some projectors just cant handle stuff like this. Some were meant for presentations and presentations only. BUt seriously try covering the remote sensor to see what happens. If it is an older projector the infrared signal detector might be sensitive to bright light or stuff like that.
Aug 23, 2007 | InFocus ScreenPlay 4805 Multimedia...
Logitech Harmony 550 Remote Control Logo
173 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
