Question about Frigidaire ATF6000ES Front Load Washer
Just had an Affinity front loading washer delivered today. Did four loads without any issues, clothes are clean and smell great. After the washer was idle for about an hour, it started beeping, and the Timer display as well as the lights on the front panel started flashing off/on and beeping short/long. Any Ideas?
  • 85 Answers
Try disconnecting the power for at least 30 seconds which might reset control if this fails call service the control is faulty you have a 1 year full warrenty
Posted on Dec 21, 2008
I have a foul smell coming from my washer everytime I use it...It almost smells like sewer gas...HELP!!!
you probably just need to clean the bellow. Thats the rubber that goes around the tub and door. f not cleaned, it will get moldy and smelly. Theres a tablet that you can buy called affresh. just put the machine on a regular cycle if it doesn't have a clean or sanitize cycle, and put the tablet in. Let the machine complete the cycle. (without clothes). You can even try wiping the bellow out with vinegar. after each wash i suggest you wipe the machine out, drying the bellow and glass. Leave it open for about half an hour, to let it air out.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
I have an affinity washer that has an odor and my clothes come out smelling bad. I don't leave clothes in for any period of time. If they stay in for even a couple of hours, I have to rewash because the...
You have a build up of undesolved soaps in the system. Do 2 hot washes twice a day for maybe 3 days without washing in and no soap. Old soap needs to be desolved and drained away. See if there is a difference. Note, Put only 1/2 of the soap in and work from there.
Nov 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Smell still in clothes
Try adding baking soda to the wash. We have the same issues (son works on a dairy farm) and will on clothing resort to chlorine bleach even on colors in small amounts. Eric
Jun 17, 2009 | Frigidaire Affinity ATF7000E Front Load...
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
HE Washer leaves clothes smelling bad
Peace,
ngafm at your service,
How old is the washer?
And how long has it been smelling bad?
Some front loaders over the years have had this problem and the worse used to be the Maytag Neptune!
This is what I tell my customers to do:
Friend,
ngfam1 At your service!
It is normal for some frond load washers to have a little water left in the inner tub after the wash finishes!
I do tell my customers to run the washer once a week without clothes and with hot water and 1/4 cup of bleach. And then make sure to do only white clothes directly after wards as not to get a drop of beach water on a colored article of clothing!
Then leave the door open after every load when not in use!
If this will not help I would call frigidiare and tell them you must have it replaced that it is affecting your family because of the mold smell!
Believe me they will swap it out after all the money you spent on it, you deserve it! BUT REMEMBER MANY people have this problem with some front load machines!
if it's not new then perhaps the pump is faulty or the lint is clogging int he pump of the machine!
Let me know what happens!
Bless You,
please give me a rating before you sign off!
ngafm
Sep 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
167 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
