Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan cover needs replacing
My 2.0 spacesaver GE microwave front fan cover has come off and the plastic tabs where the screws go in are broken on both sides, where can I find a replacement for the entire cover?
  • William Miller
    William Miller May 11, 2010
    Also, they call it the grille.
  • GE Master
  • 9,149 Answers
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 21, 2008
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
We have the same F3 problem with our rangetop microwave. ..GE JVM 1650. We have a replacement keypad that a repairman ordered 2 years ago but did not need. How do you remove the old keypad and install...
Hi, I have a jvm1631 modle that looks like yours,on mine you need to remove the grill on top and then you should have a screw above clock,remove screw and lift up and the whole assemby will pop off.Then you will see tabs all around edge that you psuh in to remove plastic cover then you can unplug all wire harnesses and replace keypad. Just remember to unplug M/W first.Hope this helps.
Mar 05, 2011 | GE JVM1650 1000 Watts Microwave Oven
Trying to replace handle on GE microwave oven #JVM1631WB. Have already removed plastic cover that trims the glass on the inside of the door. This exposes two screws on the handle of which I have removed....
You order parts and find helpful exploded view diagrams here.
I'd recommend that your bookmark this link to your favorites.
Jan 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
GE Spacesaver XL
fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Jun 20, 2009 | GE JVM1339BW/WW Microwave Oven
Light replacement
Hi, Remove the 2 screws in the grille, the grille pulls straight out (with the door open is a little easier). Then above the light is a cover plate which is removed by the two screws on the plastic frame. You will see a little tab that allows you to lift that cover plate out gaining access to that bulb. As always you should be safe and turn off the power before you repair any electrical device. Good Luck!
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave 2 years old
unplug the microwave first then pull the cover off the top front of the microwave with 2 philipshead screws, the unbolt the control panel with the one screw. let it hang down the you should be able to see tha fan.
Dec 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
43 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
