Question about Philips 43PP9202 43" Rear Projection Television
43pp92 requires adjustment?
The tv turns off after a few seconds, then the power button flashes 9 times. A posting stated it need adjustment. What is in need of adjustment? Please be a bit more detailed.
    President:
  • 1,284 Answers
Sounds like more than an adjustment to me.
Posted on Apr 18, 2007
SOURCE:
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
My tv turned off while I was watching it, now it won't come back on but the power button on the front flashes. The button flashes 5 quick times stops for a second then 9 times, then starts over. What do...
You have an open power crcuit on one of the transistors, also the display board has probloems ( 5 flashes)
This is not DIY stuff it requires special tools and a knowledge of circuit diagram redaing and the ability to retune the boards. dor a 52" I deem t6he cost around $600.00
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | RCA R52WM24 52" HDTV Projection Television
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
I have a Magnavox 51" Projector TV. Model 51MP392H/17
Hello bullmuscle,
This is a power supply problem, I would suspect the HV power supply because the primary and secondary supplies anymore are tied to the HV power supply. This type of repair requires certain pieces of equipment, to test voltages, look at signals, and to if need be test for shorts in inductors (Switching PS transformer and Flyback transformer). I would not recommend that you try to fix this yourself, The cost for this type of problem is not that expensive and can be done in one evening, if the parts are available. You may be fortunate and it could be just a blown fuse, in the HV or LV power supply circuit
I hope this helps,
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Philips 42in HDTV rear projection won't power on.
There is a reason why people give these away. Very expensive to repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
