Question about Dell Axim X5 Pocket PC
PDA will not turn on
Hi Over the weekend one of my handheld units (Dell Axim 5)was dropped and now it will not turn on. Please advice.
    Problem Solver:
  • 5 Answers
If it isn't completely broken, I would recommend a few things:
1.hold down the power button, and push reset. It will ask you if you want to wipe the contents of your device. Push the button to cancel.
2.Pull the main battery and the backup battery. This will wipe everything on your device but it may get it up and running again.
Posted on Jul 09, 2008
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
Dell axim x51v pda
You need to do a hardreset on the pda to get the password removed.
Jul 24, 2008 | Dell GG057 for Axim X51, X51v
Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
Aug 06, 2009 | Dell Axim X50v Pocket PC
REINSTALLATION OF DELL AXIM 50 PDA
You will need the disk that contains the firmware. The best thing to do is check on Amazon or ebay and upgrade to the highest firmware your device can accept. I belive the cost for a downloadable copy is between $5-10. If you do this make sure to follow the instructions for you can irrevocably render the device useless. :-(
Apr 16, 2009 | Dell Axim X50v Pocket PC
The ''power'' start button does not work
i have a dell 50 axim , the start button will not start the pda ...do you have a solution.
Apr 09, 2009 | Palm Tungsten E2 Handheld
Dell Axim x51v
You can get a replacement rechargeable one at batterytrader, here is the link - Dell Axim X51 battery, they also do a couple of extended versions just search on the site, this also fits the dell axim x50 pda batteries
Sep 18, 2008 | Dell Axim X50 Pocket PC
Good Eevening :
You could get original disk from ebay at times but all you need is the Activesync that can be downloaded from Microsoft. Get Active sync 4.2. The newer ones do NOT work with the X5.
Good luck with the wireless card. The Axim does not play well with many of them. (sometimes works but mostly not) Try drivers from d Link and be sure to remove the old drivers first.
Dec 02, 2007 | Dell Axim X5 Pocket PC
Dell Axim Touchscreen Quit Working
probrably your touch screen component got broken when you drop it thats why it no longer functions....
Oct 29, 2007 | Dell Axim X5 Pocket PC
Password forgotten
To do a hard reset:
Press the Power button to turn the Axim unit On.
Press and hold the Power button down while using the Axim stylus to
press the Reset button at the same time.
Release the Power button and the Reset button.
TheTo clear all data in the memory screen appears.
Press the Contacts button on the Axim to delete all of the data in the
memory of the Axim handheld.
5
Press the Mailbutton on the Axim to cancel the operation without
losing data.
Sep 14, 2005 | Philips Nino 210
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
Dell Axim X5 Pocket PC Logo
59 people viewed this question
Alun Cox
