Question about Sigma Cameras
I have a Sigma 18-200 3.5-6.3 lense and use it on a Canon xTi Rebel. The lense is a year old and have recently noticed that at the 18mm focal length that the f stop no longer opens up to 3.5 but only to f4. I have not dropped or jarred the lense. Also I have noticed that at the 200mm focal length the f stop opens up to 5.6 not the 6.3. Any advise would be appreciated. Jim Caldwell
  • 2 more comments
  • James Caldwell Dec 21, 2008
    I cleaned the gold contacts and it does not seem to have helped. Any other advise would be greatly appreciated. Thank you.
    Jim Caldwell
    Any idea why this lense would show these problems after a year of working well? And do you have any other suggestions to try before sending it in for repair? Thanks.
    Jim Caldwell
    I am going to contact Sigma and ask them if I will need to send the lense in. I will let you know the outcome. Also I plan on exchanging lenses with a friend that shoots with a Canon to see if the problem occurs with a different lense. Thanks.
    Jim Caldwell
  • James Caldwell Dec 24, 2008
    I took my lens and put in on a friends camera and it did the same thing. That leads me to think that it is a problem with the lens and not the body. I have also contacted Sigma and they reccomend that I send the lens in. I will let you know how this turns out. Thanks for all your help.
    Jim Caldwell
  • 916 Answers
Replace the lens and you should be all set
Posted on Dec 24, 2008
    Master:
  • 479 Answers
Yes its the lens problem and contacting sigma will definately help you if they provide u with the replacement lens.and also check out with your friends lens and let us know. keep us updated. thanks.
Posted on Dec 21, 2008
  • 928 Answers
Its possible that either wear and tear got to it or it went off thread. If that is the case then the only thing is repair. Since it is opening up to a point that means that its either dirt or threading. So basically no other options left.
  • 6,487 Answers
There's a big possibility that the lens is already bad and needs a replacement.....
  • Mark Gil
    Mark Gil Dec 21, 2008
    That will be better trying a different lens so if the other lens work fine this lens that you have really needs a replacement already...
  • 10,594 Answers
Please clean golden terminals of Sigma 18-200 3.5-6.3 lens, may have got clogged / dirt.
  • Shahid Electronics
    Shahid Electronics Dec 21, 2008
    Please perform RESET camera function while Sigma lens is attached with camera.
    This will help to set camera and lens mechanism to clean any firmware glitch, if any.
Are older Sigma Quantaray lenses that I used with a 35 mm SLR Canon Rebel 2000EOS compatible with new DSLR Canon bodies?
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
Sep 02, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Lens will not change aperture setting.. it's stuck on F4. Should be able to change to F2.8 Michael
You'll notice that the maximum aperture is specified as f/2.8-4.0. The lens has a maximum aperture of f/2.8 only at the 17mm focal length. At the 35mm focal length, the maximum aperture is f/4.
Does the lens open up to f/2.8 when you zoom out to 17mm?
Feb 17, 2011 | Sigma 17-35mm f/2.8-4.0 EX Aspherical HSM...
My sigma 105 lens do not go to f2.8. it reaches only f3. tanx. macario sakay
If this is the Sigma 28-105mm f/2.8-4.0 as in the title, then the maximum aperture will vary with the focal length. It is probably only 2.8 when the focal length is zoomed to 28mm. It will be 4 at 105mm, and at focal lengths in between it will be in between.
Nov 17, 2010 | Sigma 28-105mm f/2.8-4.0 Aspherical...
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Jun 28, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Whats the best economical lens to use for indoor photograph with
If you are new to photography in general and especially SLR photography I would suggest holding off on buying any lenses besides the 18-55mm.
The reason I suggest not buying extra lenses just yet is coz you need to get to know your camera and if you are new to SLR photography then you need to get your fundamentals right. Sure the 400D will let you shoot in full auto mode but you will really not learn much doing that and certainly not be making the most of your camera in that process and that will extend to your new lenses too.
Get used the the control, the 18-55 is a great little cheap lens with the pop up flash it will work great for most family pics. The 55-200mm is a new "cheap" lens, its been marketed as letting you go beyond 55mm thats why it starts at 55mm goes to 200mm.
Hope this helps you...
Jan 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon xti low lighting
In low light you need a high ISO setting, probably 1600.
You also could do with a lens with a low F number to let in lots of light. You can get a fixed focal length F1.8 cheap but might find the lack of zoom a problem.
A decent zoom with a low F number is going to be expensive.
The EF-S 17-55mm F2.8 IS for instance has a list price of around £800 / $1200 !!
You can get a non-Canon one which would be more affordable and you also won't need the IS at short focal lengths (although it always helps). Have a look at Sigma and Tamron in the F2.8 to F4.0 range but check the online reviews to make sure they are of reasonable quality.
Nov 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sigma 70-300 AF lense
if the lens is the older type with a macro switch which has 2 screws holding it on to the lens it will not work.If it a super 70-300 you can put the camer on AV set iris to F22 if you have a stopdown button see if the lens stops down it ok if noe it will need a rechip or a new interuper
Sep 27, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Digital slr camera
You'll need to use your camera in manual mode.
If you want the subject sharp, but the background blurred, use a large aperture and high speed exposure. This will reduce the focal length.
Remember that a large apertures are often used for night shots because they allow more light through the lense. A fast exposure will prevent the shot from being over exposed if you are taking it in daylight.
Flash photography is not recommended for the effect you are after.
Mar 24, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Lens Compatibility
The XTi does not have a "full-frame" sensor, so vignetting should not be a problem with this lens.
Jan 29, 2008 | Sigma Cameras
Cameras Logo
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
