Question about Garland H283 Gas Kitchen Range
How do I remove the oven door on a Garland Range
I need to remove the oven door in order to remove the oven floor to access the pilot and thermocouple.
    Novelist:
  • 125 Answers
Hi, is this unit a convection unit? usually you don't need to remove the door to replace the thermocouple, if it is convection unit, you will need to shut the gas off, remove the safety, and there are two metal plates covering the burner area, take those out, the next thing is to remove is the burner, it is usually just fitted in the back, once this is out, as the pilot is attached to it, you can replace the t'couple now, assemble reverse.
If you really need to remove the door, and you are really lucky, remember to undo the spring hooks holding the door so it does not snap the door closed during disassembly, usually you can just pry up on the triangle near the hook, releasing tension to unhook the door hooks, leaving the springs attached. You can just take the screws out that hold the top of the door, the bottom of the door, and I think the handle, then the door skins split, and on each side at the hinge, there is a set of bolts holding the hinge in place, remove these, and you should be able to remove the door, otherwise you need to take the bottom kick plate off, along each edge inside the door frame, are screws holding the outer channels in place, remove these, and down along the inside of the kick plate edge too. Easily pry these away from the oven body, older units had a solid piece from front to back, and you had to remove the entire side panels, or were spot welded altogether, all you can do then is pry them back best as possible, and hopefully they won't crease. Inside these channels are the hinge plates that the hinge goes into, unbolt them, slide the door out, and there you have a door in you hand. Garland has a kit to replace all of these parts as you go, if they are badly worn. I know, allot for a thermocouple. Hope that helps, and thank you.
Posted on Jan 04, 2009
GAS TO STOVE WAS TURNED OFF FOR COST SAVINGS BECAUSE NOT USED. OVEN PILOT LIGHTS WON'T LIGHT CAN'T SEE WHERE HOLE FOR LIGHT IS SO TO BE CLEANED??IT LOOKS LIKE A BLEEDER VALVE FOR BRAKS IS HOLE AT...
To light those pitots remove oven floor& access panel below the doors,for each oven will be a gas valve inside of the panel below the doors and has a red button. push that red button,light pilot inside of oven near the main burner,hold red button for 30 seconds and releas.Pilot should be on,repeat for other oven. If pilots go out after red button was held down for 30 seconds the part called the thermocoupler will need to be replaced
Aug 18, 2011 | Garland H283 Gas Kitchen Range
HOW DO YOU LIGHT THE PILOT FOR THE OVEN? OVEN I
Remove the oven floor & the access panel below the door,inside of lower access panel their will a gas valve with a red button on it, push red button,light pilot burner connected to main oven burner,hold red button for 15-20 seconds,release red button and pilot should be on.reinstall panels
If you release red button and pilot goes out the thermocoupler needs to be replaced
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Imperial IR-6-C Elite Gas Kitchen Range
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Every couple of days the pilot light goes out.
Hello. It sounds like you are able to relight it, and all is good till the next time. I would suggest replacing the thermocouple for the oven, and cleaning the pilot. The pilot is probably dirty, they draw dust into them while burning, and thermocouples are reasonably priced. You could be having a problem with your pilot safety, the part with the red button that you push to relight the pilot, however it is easier, and cheaper to get a new t'couple,and clean the pilot first.
You can go to: www.garland-group.com or call them for parts 1.800.424.2411. There are many part suppliers online that can get what you need.
Feb 04, 2009 | Garland H286 Gas Kitchen Range
Change thermocouple Garland range
I know the question is a little older, but maybe it helps someone else... I just did the job and it turned out to be much easier than I thought it would be. The whole burner assembly slides out, so you don't have to work in that small space!
Simply turn off the gas, disconnect the two pipes that go from the oven to the valve (gas and thermostat), disconnect the two door springs from the burner unit, remove the screw that holds the valve, remove the two screws that hold the burner in place and simply slide the thing out. You may have to loosen the right half of the heat protector plate to get it out. That's it.
Jan 31, 2009 | Garland H283 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
How do I remove the overn door on a Garland range
please if you can, provide a model#, or more information, I have never had to remove the door in order to get the pilot, wanted to, but not necessary :)
Dec 21, 2008 | Garland H283 Gas Kitchen Range
Garland Range
You may need to hold the red button for a couple minutes...
Apr 23, 2008 | Garland H284-24G Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
825 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
