Question about Sony KDF-50E2000 50" HDTV
Cooling fan makes to much noise - Sony KDF-50E2000 50" HDTV
Replace fan by removing entire rear panel. Look at lower rear left of rear of TV. Dusty vents are a sign that debris may have entered the fan bearings. Remove screws and be careful not to lose the rubber vibration mounts. The part is made by Phillips. Check for part number 178733321 at tritronicsinc.com for about ten dollars. I'm ordering a fan today.
Posted on Jan 12, 2009
HI, my laptop is three years old, getting some noise from the fan, My question is can the fan be lubricated,
Have you tried blowing air through the cooling duct to clean out the dust that gets caught up in there?
Nov 13, 2013 | HP (158800-001) for Compaq Presario 1246,...
Loose fan belt
It can be worn out fan belt or the fan is got dried up and needs lubrication.Inspect fan belt.
Check the help link mentioned below:----
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Dec 09, 2012 | 2007 Chevrolet Kalos 1.2
Hp proliant dl 180 g5 cooling fan issues fan given noise
I would power the server off. Blow it out with a can of air. Power it back up.. If it is still making a noise, you need to replace the fan.
Jul 27, 2012 | HP ProLiant DL180 G5 Server
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Dec 16, 2010 | HP (219426-001) Cooling Fan
Air conditioner fan is making a loud noise
1. Could be a caught foreign object between A/C (air conditioning) fan and cooling radiator, producing this loud noise.
2. Could be a damaged fan blade, mowing the cooling radiator.
3. Could be a loud noise comming from the fan's electrical motor.
4. Could be a broken off fin (small wing) of the cooling radiator, striking the A/C fan, producing this loud noise.
Jun 14, 2010 | Dodge Grand Caravan Cars & Trucks
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
Jul 20, 2009 | HP (219462-001) Cooling Fan
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
My CPU is making lot of noise especially when I'm using programs like Adobe reader
The CPU wont make noise unless its frying. So its either your hard drives, cd drives, or your fans.
If its your fans i sugest buying newer "Cool Master" fans that are powerful but less noisy
Oct 20, 2008 | Mesh 80mm Aluminum Fan Filter Fan Kit
Sony KDF-50E2000 50" HDTV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
