Question about Dishwashers
Dishwasher was moved due to flooring & water now will not come in
Dishwasher may have dropped some under the cabinet due to flooring change, motor spins, but no water comes....
  • 85 Answers
1st check to see if the water supply is on , check for kinked supply line to dishwasher ,check to see if electrical connections are on valve and 1 more thing is to check if float is jammed (float is a mushroom shaped part located inside front of tub on bottom) just pull up slightly
Posted on Dec 21, 2008
How to remove dishwasher
  1. Unplug the dishwasher, usually under the sink.
  2. Turn off the supply faucet to the dishwasher, also under the sink.
  3. Disconnect the dishwasher supply hoses and the drain hose which usually empties into the garbage disposal. Have a small bucket or pan and some towels ready, the water in the hoses will leak out.
  4. Open the dishwasher door. There should be 3 or more screws holding the dishwasher to the cabinet. Remove these screws and re-close the dishwasher door.
  5. Grab the dishwasher door handle and gently pull the dishwasher outwards, lifting slightly and moving side-to-side as space allows.
  6. If it is unable to move due to the trim plate at the front of the base of the dishwasher, remove that too. Otherwise, just leave the trim in place.
  7. Gradually continue to pull the dishwasher outwards, and push/pull the hoses and power cord out along with it.
Apr 04, 2014 | Kenmore 24 in. 17032 Built-in Dishwasher
Pump keeps running, does not take in water and program does not move forward.
It sounds like the flood protection system has been activated. This is most likely due to water in the bottom of the dishwasher (under the washing compartment) or it could be due to a faulty float or float switch.
The first thing to do is check the float inside the dishwasher. It's the dome/mushroom shape plastic part in the bottom of the wash compartment. Have a feel around under the dome and check there isn't anything trapped underneath it (maybe cutlery or a build up of waste). If something is stuck in there, simply removing it should be enough to get you running again.
If it's clean underneath try pushing the dome down gently in case it's just stuck in the up position. If it pushes down, lift it up and down a few more times, clean underneath it and make sure it drops down on it's own when you lift it and let go. If it falls freely, you're good to go.
If there's nothing under the float and it moves up and down freely, next check for water in the bottom of the washer. To do this, tilt the washer forwards then backwards to about 20 degrees. Obviously, if it's under-counter you'll need to pull it right out before doing this. If you see a pool of water on the floor then you have water leaking into the bottom of the washer!
There are several possible causes of this - some are simple and easy to correct - but you should do these checks first, then post back here for further assistance.
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Whirlpool ADG 7550 Dishwasher trips out all my electrical sockets as soon as its plugged in. It failed whilst in mid wash. Any advice?
It is possible there is a short in the electric system in the dishwasher. There are two possibilities
1. there is a leak to the earth due to some water leakage and this causes the earth relay to trip.
2. the dishwasher motor coil or capacitor is shorted and drops the circuit breaker.
If it is related to 1, then best to take the dishwasher out from the cabinet and check with multimeter if power plug Live is showing short with Earth connection. You will have to find source of the water leak onto the power board.
If it is related to 2, then isolate the motor capacitor and try again. But 2 is unlikely if the breaker trips even if the dishwasher is not turned on.
Please post a comment if you find anything.
Sep 05, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Fisher paykel dishwasher dd601I runs complete normal cycle and finishes normally. 2-3 sec. after completion the washer motor srarts to run and the f1 fault (flood sw. activated) is dislayed. When the power...
Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
Jan 20, 2010 | Dishwashers
Installing a under the counter dishwasher
The dishwasher doesn't have to be between cabinets, but it does have to be enclosed on both sides, and it can't support the countertop. You can put an end panel there, which is just a finished panel with trim on the front to match the cabinets. Make sure it is straight and securely attachedd to both the floor and the countertop. Also make sure that you can route the water and drain lines out the other side.
Sep 28, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
No water in dishwasher
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Apr 07, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
