Question about Samsung SMH7178STD Microwave Oven
When Cooking the Microwave "bogs down", everything else works
I have a Samsung OTR SMH7178STD Microwave. I just moved and the microwave is acting oddly. When cooking it bogs way down, the lights dim and the panel LCD display dims. The food is still heating, but not nearly like it was. It almost seems as though there isn't enough amperage. Any suggestions?
-Shawn
MicrowaveSvc
  • 9098 Answers
SOURCE: SMH7178STD Not working properly
E4 means your thermistor (temperature sensor) is shorted or caked with grease, making it look shorted.
Normally you can get Samsung parts here: http://www.samsungparts.com/search/search.asp
But that part does not show up on a search so you'll probably have to call them:
J & J International, Inc.
311 Route 46 W, Suite E
Fairfield, NJ 07004
Tel 800.627.4368
Fax 973.276.9078
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Danby DMW162BL-OTR not cooking after loud popping sound
I would say the high voltage diode blew.
I would check their Web site for links about parts, spares, or service.
http://www.danby.com/
Posted on Jul 04, 2008
buddymcl777
  • 67 Answers
SOURCE: Samsung microwave oven turntable doesn't turn
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
Posted on May 01, 2009
  • 1214 Answers
SOURCE: Samsung microwave doesn't heat food.
Microwave ovens that do not heat, and failed as you have described, have 1 or more of the following failed components, in order of cost -
1) Fuse
2) Diode
3) Capacitor
4) Transformer
5) Magnetron
4 and 5 are interchangeable when it comes to cost.
Try replacing 1 and 2, then 3, then it's decision time of whether to buy parts or replace the microwave.
Posted on Dec 11, 2009
rulds2008
  • 3866 Answers
SOURCE: Cooking bag of vegetables in
Sounds like some metel was interduced, now you cannot just put any bad of vegies the very paint might have some for of metals in it on the bag, Sounds like you blew the magntron in this bad boy and its going to cost a buch of money to fix it. Now that is caused by metal intruducted in the unit. A magatron might cost $100 bucks or more. Do not shoot the messenger i was not there when the vegies blew the unit nor do i know if it was save to put the whole bag in there. Let me know i am here to help, please do click accept button
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 24, 2010
Cookbook for SMK9175 Samsung convection microwave
Hello, Pamela -
This is the link to the web page where you can download the manual (which includes instructions on cooking):
https://www.samsung.com/us/support/owners/product/otr-microwave-smk9175
You will need to select the language for the manual before downloading.
You will need Adobe Reader software (free), since the manual is a PDF document.
Jan 06, 2018 | Samsung Microwave Ovens
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
OTR Samsung Microwave fan comes on with no reason. Any way to fix it?
Does this happen while you are cooking on the range burners under the control panel?? These type microwaves have a heat sensor built into them in the area of the control panel bottom. If the microwave control gets too hot from cooking on the stove below it the heat sensor will turn the fan on to keep the control panel from getting heat damage. The fan should go off after everything cools off.
Apr 13, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
My samsung SMH7178std microwave doesn't heat anything up. it makes a buzzing sound after i set timer and press start.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jgk
Feb 10, 2010 | Samsung SMH7178STD Microwave Oven
During cooking, the microwave will work for about 3 minutes then completely shut down.There appears to be a complete power failure.After the units sits for about 5 minutes,it resets itself and you can cook...
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Oct 20, 2009 | Samsung SMH7178STD Microwave Oven
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Microwave not heating
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
If it's fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Jan 27, 2009 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
125 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
