Question about Maytag MER6772 Gemini Electric Kitchen Range
Lower over door won't open
The lower oven door on my Gemini Electric range won't open. I came home adn found the control panel locked and the lower door won't open. I did not try to clean the oven. Help!
  • 61 Answers
The first thing to check is the oven sensor you will have to purchase a new one and have a local service co. come to put it in and unlock the door for you. good luck
Posted on Dec 22, 2008
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
What is Error message F9-5, bottom oven door is locked
Hello & Welcome to FixYa
Error F9-5 in your Maytage Gemini means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven door locked and unable to open the door.
I have the same problem. Happened a few days ago. Have you found a solution?
Oct 30, 2010 | Maytag Gemini 30" Self-Cleaning...
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
242 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
