Question about Hotpoint Refrigerators
I have a fridge which doesn't seem to be working properly. Could the fact that it's in a non heated, cold room cause this prob. The fridge is cold just don't hear it running.
  • luther13z Dec 21, 2008
    Found my own answer, thought I'd share.
    Most
    owners manuals explain the environment to which the machine will
    operate. I can remember getting calls from people with refrigerators in
    the garage and the complaint being,the stuff in the freezer is soft.
    The manufacturer states if the temperature drops below 65 degrees the
    unit will not run enough to maintain freezer temperatures.As for the
    troubles in the hotter days of summer it can't keep up if over 90
    degrees.
    this helpshttp://www.apwagner.com/index.php?main_p...
  • 4 Answers
If the fridge is cold it will not run a lot .Does it do the same when it is hot out side?
Posted on Dec 21, 2008
The fefrigerator part freezes everthing
Fridge freezing up and no fan or air circulation:
The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
Sep 09, 2014 | GE Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
I BOUGHT A USED HOME APPROXIMATELY 1000 SQ. FT. IT
quantity of gas alone does not make for cold air
to understand that it is necessary to understand how an air conditioner or fridge works ( ac, car ac , fridges , freezers etc all work on the same principle)
Simply put it is a heat transfer device where the heat of a room is transferred to outside the room
IT does this by allowing an extremely volatile liquid to evaporate ( being boiled off by heat in the room)
the gas is then collected by a compressor and recompressed back to a liquid
this process releases the heat back outside by the condenser and so the process is repeated until the amount of heat in the room reaches the temp set at the thermostat
Basic I know but it is sufficient to know that there is more than gas at work
if the compressor is inefficient ( worn , faulty etc) it cannot compress the gas properly and so instead of releasing liquid at the evaporator , it will be releasing gas which is not boiling off and removing heat
next is the thermostat
it controls the TX valve that regulates the amount of liquid that is allowed to enter the evaporator to collect the heat to be removed
next there is the condenser
if the fan is not working it will not remove the heat from that unit and so the compressor cannot do the job as it goes into over pressure and shuts down
Good advice is to get a second opinion from an accredited service technician, preferably a carrier service technician that has the technical knowledge of the make to be able to properly diagnose and test each component of the system
every system is repairable if the parts are available but the deciding factor is the repair cost against the energy saving costs and parts availability of a new unit so get quotes and then decide the action to take
Mar 01, 2017 | Heating & Cooling
Freezer doesn't seem cold enough, took over 24 hours to make ice cubes!!! Small fan at the back of the freezer doesn't seem to work regularly, fridge seems ok
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 08, 2010 | Refrigerators
Please can you help me my fridge peezer FFA60 FUTURE fridge freezer isnt working right, my freezer is great but my fridge seems to stop & start altough the light is still on, if I turn off plug it...
that model number does not come up in my program, so I cannot give you any concrete advice. The fact that your freezer is great is a good sign, nothing major. Sounds like you may have a bad freezer fan motor, not blowing cold air down to the fridge section. but the fact that it is intermittent like that, you might have a faulty main control board. Without proper inspection, I cant say for sure.
www.FixMyFridge.net
Mar 08, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Acquired second hand electrolux er3167bn fridge freeze. worked ok for about 10 days then fridge started to get warm, eventually ended up room temp. engineer said to switch off fridge freeze and leave for...
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
May 02, 2009 | Electrolux ER3167BN Bottom Freezer...
(1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Jan 12, 2009 | U-Line 15R Compact Refrigerator
Refrigerators Logo
59 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
